Monitors
yek
Monitors
Post by yek » Fri Jul 04, 2008 7:34 pm
what should i get, i'm thinking about spending around the 500 us range ... what kind of speakers do you use and are they good, how much? etc.
yek
Post by yek » Fri Jul 04, 2008 7:35 pm
it should also be noted that i'm not a professional and will probably be indie my whole life. i still want good sound though.
thanks.
yek
Post by yek » Fri Jul 04, 2008 9:05 pm
what about the yamaha hs80m? is that enough to spend, they did create the industry standard for awhile there with the older model .
GeneralBigbag
Post by GeneralBigbag » Fri Jul 04, 2008 9:44 pm
I'm using HS50s, and they are quite brutal in the sense that they won't flatter your sound at all. I've heard higher-end stuff which has more detail, but is less confrontational.
I'd say the HS50s paid for themselves within a week of purchase - I was doing some master eq stuff on some finished tracks, the sort of +-1dB kind of eqing, and the before/after HS50s mixes are night and day when it comes to clarity on every system I've listened to them on.
virb.com/ookpikk
GeneralBigbag
Post by GeneralBigbag » Sat Jul 05, 2008 6:54 am
If the sound is comparable though, between the HS50/80s and the NS10s, I've yet to hear a home stereo remotely near this harsh. Like I say - there are certainly clearer, more detailed speakers out there, but these ones really won't flatter you at all.
virb.com/ookpikk
