Talk Box?
drummy
- Gear: Univox K-2 Mini-Korg 2
- Location: Northfield, Illinois or Milwaukee, Wisconsin (I go back and forth a lot)
Re: Talk Box?
I believe they used a vocoder. You can maybe buy a MicroKorg for a vocoder? I think I saw a guy using the MicroKorg vocoder to replicate the vocals on Harder, Better, Faster, Stronger. Please excuse my ignorance on the subject, I'm drunk.farrm06 wrote:I'm about to buy a talk box to do some Daft Punk style vocals. What do you guys recommend as a synth sound to do the vocals through? My main synth is a Nord Lead 2x.
Good lord, not the vocoder/talk box discussion again.
They do not sound alike and a lot depends on the input signal.
One More Time (the Cher effect) : Pitch correction - Antares Autotune.
Around The World : Talkbox.
Robot Rock: Vocoder.
Talkbox demo: (when there's a plastic hose involved, it's a talkbox).
What a vocoder does:
You can build your own talkbox -
The input signal for a talk box is served best as a saw wave - anything with a lot of harmonics, because your mouth is going to act as a filter. Set both oscillators of the Nord as saws, detune one of 'm a few cents, and use that as the input - it'll do fine. The entire religion that has sprung up around the DX100 is ridiculous - any 4-op FM synth will do, it's just that the DX100 is cute and small.
- Box
- Gear: Roland JP-8000
Roland JX-3P
Roland JX-8P
1972 Wurlitzer Console Piano - Band: Neo Decorum
- Location: Land of oscillators, filters, and other really cool looking stuff.
What I do for a cheap "talkbox" is to run earbuds that're tied together out the headphone output and place them in the back of my mouth and then "talk" into a mic connected to my amp. Ye it's not an official talkbox but it gets the job done.
But the difference between the two is that with a talkbox the synth is the sound source and your using your mouth to shape the sound, talking synth effect. With a vocoder your voice is the sound source and the synth will filter/alter it, robot effect. Two completely different things with two completely different outcomes.
- supermel74
- OriginalJambo
- Gear: Check my sig
If you are looking at a talkbox I'd recommend a Rocktron Banshee - has a built in preamp so it's really easy to set up and use. It sounds pretty damn good too.
Here's some talkboxin' I recorded over Daft Punk's Digital love. Be warned that I screw the rhythm up quite a bit.
Notice the talkbox vocals sound nothing like the original ones - I really, really don't think a talkbox was used on this track originally. However it still sounds pretty cool. Oh and I used a Casio CZ-3000 to provide the carrier for the talk box, but anything that can provide a sound rich in harmonics should do the trick nicely.
- jaypodesta
ColorForm2113
- Gear: tin cans and rubber bands
- Band: Me twiddling in the corner...
- Stab Frenzy
- killanator
- Real name: Carl
- Gear: Alesis Quadrasynth, Roland SH-201, Various MIDI things, Samson MediaONE 5a Active Studio Monitors
- Band: Solo
- Stab Frenzy
http://www.google.com.au/search?hl=en&q ... lkbox+workkillanator wrote:wait im conused, how does a talkbox work, and why is it in his mouth(i know this is a noob question but i always thought talk box and vocoder were synonymous)
ColorForm2113
oh well alright! i dont know where i heard that but im glad its wrong. definately adding talkbox to my wish list nowStab Frenzy wrote:Synth -> Talkbox, Mouth -> Mic.ColorForm2113 wrote:whats the best way to hook a talkbox up to synths.
No.Because with guitars they are placed between the amp head and speacker cab right?
- OriginalJambo
I'm afraid this isn't always entirely true.Stab Frenzy wrote:Synth -> Talkbox, Mouth -> Mic.ColorForm2113 wrote:whats the best way to hook a talkbox up to synths.
The Rocktron Banshee is a special case - it has its own amplifier built-in so in this scenario "Synth -> Talkbox" would be exactly what you'd want. However most conventional talkboxes (including the original and popular Dunlop Heil) need an amplifier in between the talkbox and instrument to get results as it's expecting powered speaker level, not line level.
Here's a few diagrams from the Jim Dunlop Heil's manual that clearly show how to connect that sucker up:
Further more you can indeed connect the talkbox in between your amp and cabinet. Doing so will allow you to bypass the the talkbox's internal driver and route the signal to your cab instead. Just stomp on that switch to alternate between the two routings.
