Multiple instances of FX running parallel
- tallowwaters
- Gear: LC-MS/MS
Here is the deal.
I am running something out of my pre into 6 different FX units, all parallel (so each one has its own track). Currently I have had no issue just daisy chaining the Y cables, but I feel there has be something like the 'passive multiple' Squarewave Parade used to make or some other answer. I am a little worried about the load I am putting on the output amp (which is likely negligible ) but the physical strain of those Y cables coming loose of their support and pulling on the output jack is a real fear.
Rack Patchbays won't work. It has to be compact.
- mwbassguy
- Real name: Justin
Re: Multiple instances of FX running parallel
well, most multiples on modular synths are strictly passive, so you could just get one of those modules and cover the back in electrical tape.
an avatar and a sig make one's posts more easily recognizable.
- tallowwaters
- Gear: LC-MS/MS
Thanks, will have a peak around.
- Stab Frenzy
I don't think that a passive 6-way split is officially a good idea if you're running into regular line level devices, although if it's very high impedance guitar pedals and stuff it shouldn't be a problem. Rules were made to be broken though, as long as it sounds good to you I'm sure it'll be fine, unless you melt something in the output stage of your pre cause you're drawing too much current.
I'd just make a passive splitter in stompbox if I were you. You can solder can't you? Every gentleman knows how to.
- tallowwaters
- Gear: LC-MS/MS
s**t, now you have me worried. I thought any pull would be too small to matter.Stab Frenzy wrote:unless you melt something in the output stage of your pre cause you're drawing too much current.![]()
I guess I could make one. Would I run multiple leads from the input or daisy chain the outputs?
- hageir
- Expert Member
- Gear: http://www.geirhelgi.com/
https://soundcloud.com/geir-helgi - Band: Geir Helgi
I had same thing a couple of months ago!
I found that there's this little thing called Hosa MHB -something..
Well, it was definitely made by Hosa, I remember that; because I bought one from some online-store and never received it!
I think it was a little splitter-box..
ps.
also, DOD made a little thing called Resistance Mixer, which is a passive mixer (4 in 1 out or something)
and IIRC there should be an "inverted" version of it..
ps.
MnM MD UW MEK Prophet REV2 16 Chroma Polaris K3 VFX ESQ-1 Odyssey Böhm Digital Drums Wavestation WS-1 MS-20 DPX-1 VZ-8m C1 Music Computer Synare PS-1 JX-3P E-MU MPC 2000XLSE-1X Polysix red SH-101 CR-8000 KPR-77 CS-15 SH-5 Matrix 6R
- Stab Frenzy
Would be the same thing really electrically, but i'd probably run multiples from the input so that each ground path was the same. Probably wouldn't make a difference but that's the 'ideal' way of doing it.tallowwaters wrote:s**t, now you have me worried. I thought any pull would be too small to matter.Stab Frenzy wrote:unless you melt something in the output stage of your pre cause you're drawing too much current.![]()
- hageir
- Expert Member
Hey Tallow!
It's called Hosa AJB-126!
- tallowwaters
- Gear: LC-MS/MS
Thanks guys. Looking into right now. That little Hosa mixer is one hard monkey to find!
- HideawayStudio
- Real name: Dani Wilson
- Band: Shortwave
Dont worry about the load on your preamp - it will be fine - the most that will happen is that the signal will clip or become overly attenuated due to the output stages driving into too low an impedance. As for the weight of the leads why don't you plug a short extension lead into the preamp and then plug your y-leads into that?tallowwaters wrote:Here is the deal.
What I would be more concerned about is running into potential phasing problems due to near similar multiple signals entering the mix - unless this is an effect you want of course
Speaking of multiple FX - have you ever tried feeding the output of an FX processor back into its input? - you can create some truely mad sound fx this way!
H.I.D.E.A.W.A.Y S.T.U.D.I.O
http://www.hideawaystudio.net
The Home of Novachord #346
http://www.novachord.co.uk
- hageir
- Expert Member
here's one!tallowwaters wrote:Thanks guys. Looking into right now. That little Hosa mixer is one hard monkey to find!
http://www.mooresmusicemporium.com/prod ... e113a4494a
- tallowwaters
- Gear: LC-MS/MS
Worrying about comb filtering and phasing issues in my vocals would be pointless. 2 grain shifters, a phasing delay, a reverse reverb, a continually scrolling delay time for pitch f**k, ring and frequency modulation, etc, plus layers of sharply notched and cut distorted crystal element mic'ing make fidelity a non issue.HideawayStudio wrote:
That'd be the one I saws, but I am a bit wary about the site.hageir wrote:here's one!tallowwaters wrote:Thanks guys. Looking into right now. That little Hosa mixer is one hard monkey to find!
