Tube Overdrive Pedals
synthecks
Gear: Yamaha p100, KORG MS2000, roland rs-09, Fender PA135, SUNN 215B, various pedals & keyboards
Band: Lethosomn
Post by synthecks » Tue Aug 25, 2009 8:52 pm
So Im in the marked for a thick warm ovedrive pedal and would like to stay under $200.
What should I consider ?
space6oy
Re: Tube Overdrive Pedals
Post by space6oy » Tue Aug 25, 2009 8:57 pm
i just bought an EHX hot tubes, will report back once it arrives... hoping i like it somewhere near as much as the high gain in on my sovtek amp head.
Post by Stab Frenzy » Tue Aug 25, 2009 9:25 pm
synthecks wrote:So Im in the marked for a thick warm ovedrive pedal and would like to stay under $200.
I would consider a solid state pedal, the Crowther Hotcake. Tubes aren't magic, a lot of the cheap tube overdrives I've heard don't sound as good as really well designed solid state ones.
The Hotcake is the thickest, warmest overdrive I've ever come across. They don't seem to be that well known in a lot of places, but most of the local bands I mix have at least one. I've never heard a better overdrive for organ ever, and is great on synths too but like most guitar pedals you have to make sure the gain setup is right.
synthecks
Band: Lethosomn
Post by synthecks » Tue Aug 25, 2009 10:13 pm
That looks more like a distortion pedal than overdrive
Post by Stab Frenzy » Tue Aug 25, 2009 11:09 pm
Depending on where you set the knobs it does everything from nothing to distortion, but most of the range is from overdrive to subtle bluesy distortion. You said you wanted warm and thick overdrive, it's the best for that IMO.
Solderman
Post by Solderman » Wed Aug 26, 2009 11:56 pm
Stab, the Hotcake appears to be a pedal that is supposed to work in conjunction with other drive pedals, when it comes to guitars. Would you say then, that it would have no trouble adapting to line levels, and still have similar flexibility?
--Solderman no more.
synthecks
Band: Lethosomn
Post by synthecks » Thu Aug 27, 2009 6:47 pm
I was thinking something like the blackstar pedal but am now considering using my synth to emulate the sound Im looking for
space6oy
Post by space6oy » Fri Aug 28, 2009 5:45 am
received my EHX hot tubes today... have only run guitar through it, but my first reaction - f**k GREAT distortion. disregarding miscellaneous fuzz pedals, it's the nicest warm overdrive up to massive crunch i've experienced. add simple EQ and run it through a clean tube amp as well... awesome.
synthecks
Band: Lethosomn
Post by synthecks » Mon Aug 31, 2009 11:47 pm
Thanks I'll check it out
Post by Stab Frenzy » Tue Sep 08, 2009 4:57 am
Solderman wrote:Stab, the Hotcake appears to be a pedal that is supposed to work in conjunction with other drive pedals, when it comes to guitars. Would you say then, that it would have no trouble adapting to line levels, and still have similar flexibility?
What gives you that idea? I know a lot of people who use it as their sole overdrive pedal, as well as some who use it with others. It adapts fine to line level in my experience, just set up your gain structure properly and you shouldn't have any problems.
Solderman
Post by Solderman » Thu Sep 10, 2009 12:23 am
Stab Frenzy wrote:
Solderman wrote:Stab, the Hotcake appears to be a pedal that is supposed to work in conjunction with other drive pedals...
Mostly, the tonefactor review. Apparently I have misunderstood. :sign6: The video on that page makes it more clear. Thanks for the recommendation, it does give a nice, thick sound. I'll check this one out.
