duh
TrondC
Korg KP3 & Zero 4
Band: Siesta Submarina
duh
Post by TrondC » Thu Dec 17, 2009 10:34 pm
you're all probably gonna laugh at me for this, but I tried a new approach with how I set uop levels on my gears.normally, I'd leave the master volume of my synths to about 40% and adjust the gain/level on the mixer. today, I turned the md and mono to max olume and lowered the gain... I couldn't believe it! what can only be described as "warmth" came streaming through my speakers... will leave it like that I think ;)
Syn303
Gear: Quite a bit...
Band: Syn303
Re: duh
Post by Syn303 » Thu Dec 17, 2009 10:39 pm
warmth!! are you sure it wasn't smoke coming out of your speakers?
Solderman
Re: duh
Post by Solderman » Thu Dec 17, 2009 10:57 pm
A possible explanation: If the software on the elektron devices translated volume into actual bit-depth pre-DAC, then less bits, hence less resolution, would occur at the output. Increasing voume would increase headroom in this case. OTOH, if the volume knob was an actual pot, post-DAC, then maybe there is a bit of psycho-acoustics going on, where perceived loudness is different, using different level settings at your mixer.
--Solderman no more.
pflosi
Re: duh
Post by pflosi » Fri Dec 18, 2009 12:44 am
signal to noise ratio
always, ALWAYS use top volume on synths
TrondC
Korg KP3 & Zero 4
Re: duh
Post by TrondC » Fri Dec 18, 2009 7:01 am
pflosi wrote:signal to noise ratio
will do from now on :)
as for the sound, it was the same kind of improvement in sound I got from the tubes of my esx, the bassdrums came to life so to say, really a different sound in my ears, and in a good way :D
tallowwaters
Gear: LC-MS/MS
Re: duh
Post by tallowwaters » Fri Dec 18, 2009 2:08 pm
always, ALWAYS use top volume on digital synths
fixed.
An older analog is more likely to have a sweetspot in its volume range.
pflosi
Re: duh
Post by pflosi » Fri Dec 18, 2009 2:37 pm
yes, up to the top that is ;)
or sth is wrong with your OLD synth
