Best Microphone Cables? Mogami?
kylejun06
Post by kylejun06 » Fri Dec 25, 2009 6:41 am
So, I'm torn between getting two different microphone cables. All from the same brand, Mogami.
http://accessories.musiciansfriend.com/ ... sku=338010
http://accessories.musiciansfriend.com/ ... sku=339037
Problem is, the first option is really expensive, and I need a 20-foot cable. The second option is 25-foot, but is cheaper, and is supposedly not as good as the Gold series? If anyone has experience with these Mogami cables, please let me know if I should really shell out the extra 40 or so for the Gold cables, or just stick with the Silver series cables.
And if you have any other suggestions as far as other cables, please let me know. I'm looking for a nice sounding cable! I've just heard a lot about the Mogami ones. Thanks!
Equipment: FL Studio 7, Reason, microKORG, Alesis Multimix 8 USB, Electribe EMX-1 (looking to sell/trade), Edirol PCR-M80, LSDJ, and my precious MXL 990s :]
b3groover
Real name: Jim
Band: THEO
Re: Best Microphone Cables? Mogami?
Post by b3groover » Fri Dec 25, 2009 7:12 am
If you're not running excessive lengths (ie over 100') you probably won't notice a sonic difference. You will notice a construction quality difference, though for sure between Mogami and cheap cables.
If you have any skills whatsoever with a soldering iron it is exceedingly easy to "roll your own" and much cheaper. You can buy Mogami mic cable for under $0.40 a foot.
Cruel Hoax
Gear: Moog Voyager, Roland V-Synth, Roland MC-909, Parker Nitefly, Master Room & Fostex Springverbs, Lexicon Vortex, Travel guitar, Acoustic guitar.
Band: Giorgio Moroder's Moustache
Post by Cruel Hoax » Fri Dec 25, 2009 10:45 am
Mogami cables are where it's at. I roll with a roll of bulk cable and a box of Switchcraft ends. And real solder, with lead in it! You can buy supplies to build custom cabling for all your instruments for the cost of one or two pre-soldered mic cables. Bing, bing - we have a winner!
-Hoax
"Your reality, sir, is lies and balderdash and I'm delighted to say that I have no grasp of it whatsoever." -Baron Munchausen
kylejun06
Post by kylejun06 » Fri Dec 25, 2009 11:02 am
where can i get these mogami cables and switchcraft ends?
b3groover
Real name: Jim
Band: THEO
Post by b3groover » Fri Dec 25, 2009 4:23 pm
Markertek.com
Switchcraft connectors are the industry standard but I like Neutrik for ease of use. Never had an issue with them.
http://www.markertek.com/Cables-Connect ... 2792.xhtml
That cable would work great. Looks like the price has gone up since I last ordered. Used to be $0.41 a foot I think.
Canare is also good stuff and was cheaper than Mogami but looks like the prices are similar now. Must be due to the high cost of copper; everything is going up.
Again, unless you're running hundreds of feet, any decent quality cable will be fine. It will always be cheaper to make your own. I do like Mogami because the shield is easier to work with.
Post by Stab Frenzy » Sat Dec 26, 2009 7:04 am
Cruel Hoax wrote:Mogami cables are where it's at. I roll with a roll of bulk cable and a box of Switchcraft ends. And real solder, with lead in it! You can buy supplies to build custom cabling for all your instruments for the cost of one or two pre-soldered mic cables. Bing, bing - we have a winner!
-Hoax
Same but Canare and Neutrik.
OP: It's worth mentioning that the cable makes an almost unnoticeable difference to the sound, compared to room, mic and preamp. Unless you've got the first three sorted you're not going to have to worry about the cable.
kylejun06
Post by kylejun06 » Sun Dec 27, 2009 7:34 pm
To Stab Frenzy: I have the room, mic, and preamp pretty much set out. I mean, right now, I'm running a really basic setup. A Rode NT1-A going into a M-Audio DMP3, and then into an Alesis Multimix 8 USB as my audio interface. My room is fairly decent for mic recording, but I'm going all "DIYYY MANNNNZ;LKJA;SLDKJF" and setting up a "booth" in my closet haha. I just ordered an Apogee Duet though recently, and plan on using that with Logic.
PS. Should I keep the M-Audio DMP3, or sell it and use the preamps in the Apogee Duet? I've fairly liked the DMP3, but if I don't need it I could use it to buy a Devi Ever pedal I'm craving. hahahaha. :D
Post by Stab Frenzy » Mon Dec 28, 2009 12:09 am
I'd wait til you get the Duet and then compare the two, but I suspect that the Duet is going to have better pres.
kylejun06
Post by kylejun06 » Mon Dec 28, 2009 5:40 pm
Thanks SF.
So I did some more research, and found some companies that make "custom hand-made cables" by buying Mogami and Canare cables and soldering on different ends to them. For instance:
http://www.proaudiola.com
Anyone familiar with these guys? I would go the custom route, but I don't know how to solder :[
Post by Stab Frenzy » Mon Dec 28, 2009 11:40 pm
I've heard good reports about Redco, another company like that.
Soldering isn't that hard, if you buy the stuff to make your own custom cables you'll be pretty good at it by the time you're done. And you'll be able to fix them if they ever break.
Have a look on youtube and instructables.com for soldering tutorials, it's a great skill to have.
