RD9 wrote:So I'm trying to figure out the most efficient/cost-effective effects processing setup possible (hardware only, no software) and looking for some opinions. I obviously don't want to get a reverb, delay, chorus fx unit for every instrument, but I do want some flexibility. I was wondering what other people's setups look like.
Some general questions:
- How many of you use more than one dedicated delay unit (not built into the instrument)?
- Is it normal to use only one reverb unit for the entire mix (where/how do you insert it in the mix)?
- Do you ever use reverb on instruments selectively? For ex., drums and lead only but not on bass and pads?
- If so, do you ever gang up instruments and apply an effect to them and isolate other instruments? How is this done?
- Any other tips/advice?
So far, I've been very minimal in using effects, but I'm starting to experiment a little bit more. And I've gotten spoiled with learning on the Radias where each instrument/part can have up to two effects + a master effect for all 4. Now that I'm working with separate instruments, it's starting to get tricky.
Any thoughts?
1) I have a couple outboard FX boxes. My main one is a Lexicon MX300, which I bought for live use, not really expecting much, but the reverbs blow away any plug-ins I have (and I have some good ones). Also have some moogerfoogers.
2) Depends on the music, but I would say in most cases, no. Most of the time, you'll want a different kind of reverb on percussive elements than you would on melodic parts. One reverb on everything can get muddy real quick; then again, sometimes it can sound good.
Stab covered the aux send / return thing, so no need to retread that.
3) Yes, most definitely. Selectively using reverb can really help add depth to your mixes. You want a certain part to be up front? Don't put any reverb on it. Want something to lay back a bit in the mix? Put a little ambiance on it. There's a million different ways to do it, but when done well you can effectively create depth and help balance the various parts without going nuts on EQ and such.
4) Again, the aux send / return thing is the way to go.
5) Don't be afraid to tune OFF the effects on your digital synths and see what the patches sound like without them. I'm recording to a computer and using a combination of plug-ins and my outboard stuff. I almost always turn all the effects OFF on my digital synths, especially reverb, unless it is an important feature of the patch itself. This allows me to decide what parts to apply FX to, in order to balance the mix, create depth, add space, etc. You can always add reverb later but if you track with reverb already on the part, you can't take it off.
Then again, the way I work involves very little sequencing (I use the computer more like a multitrack tape deck). If you're sequencing via MIDI, you can always change things up until the point of "printing" the mix.
