Synth Bass - Combining Sounds
Erotic Cabaret
Real name: Tyler
Gear: Pro One, SQ-80, EII+HD, NL3, MoPho
Post by Erotic Cabaret » Mon Nov 08, 2010 7:19 am
Do you guys generally use just one sound for a synth bass part, or do you combine multiple sounds?
Back in the mid 80s, it seemed pretty common to combine a DX7 bass sound with a Minimoog bass sound. Conversely, it seems like the synth bass parts in early 80s records are all one sound (eg, Dare)...I could be wrong, though.
"The Jupiter-4 will be tatooed on my heart for ever."
--Phil Oakey
cartesia
Gear: Octatrack
Bass Station 2
Band: TBA
Re: Synth Bass - Combining Sounds
Post by cartesia » Mon Nov 08, 2010 7:22 am
I dont live, cos all I have is my tetra for all synths.. but when recording I usually at least separate subbass (well.. far enough above sub level to give it just a hint of character)/rest of bass/low-mid, then sometimes go up to 3 layers if im being pedantic
portland
Real name: Zakarias
Gear: Elektron Machinedrum UW+, GEM S2, Roland S-760, Korg SDD-3300, Kawai Q-80, Yamaha TG-77, Yamaha 01x, Adam A7s, Logic Studio, Reaktor 5
Band: Romeo Alfa
Post by portland » Tue Nov 09, 2010 2:22 am
I've been thinking of trying that out. Italo disco producers got a lot of mileage out of layering a percussive digital bass octave with a simple analog bass. You could definitely do this now without it being necessarily just a rehash of the 80s.
tekkentool
Real name: Steve
Band: none currently
Post by tekkentool » Tue Nov 09, 2010 5:05 am
The Stephen Forsyth incredible rip off bass technique:
1. make the top layer.
2. Bus this original sound into 3 different tracks and EQ these so they comprise the high, middle and low. Do not do anything to the bass channel (sub 200hz ) Add a taste of distortion and bitcrushing to the mid channel. Add a stereo enhancer to the Channel you have bussed to do the highs. and a touch more distortion. (crayon filter is great for this)
3. Copy the sequenced note for this channel and make a sub bass sound. Cut below 20 and above 130 HZ. Compress.
4. add other layers for specific things (like a more percussive attack etc.)
sequentialsoftshock
Real name: Zayne
Gear: Pro One, Analog Keys, Prophet 5, MPC60, TR606, RD8, St. Vincent Guitar, Bluesbreaker amp
Post by sequentialsoftshock » Tue Nov 09, 2010 5:30 am
Erotic Cabaret wrote:Back in the mid 80s, it seemed pretty common to combine a DX7 bass sound with a Minimoog bass sound. Conversely, it seems like the synth bass parts in early 80s records are all one sound (eg, Dare)...I could be wrong, though.
Hmm... It sounds like the advent of MIDI helped make it simple enough to layer basses without multiple takes.
tekkentool
Real name: Steve
Post by tekkentool » Tue Nov 09, 2010 7:01 am
I like the real bass/synth bass dynamic. E.g David bowie's let's dance.
Erotic Cabaret
Real name: Tyler
Post by Erotic Cabaret » Tue Nov 09, 2010 7:07 am
tekkentool wrote:The Stephen Forsyth incredible rip off bass technique:)
I've read about this before. Have you tried it?
Just in general, how often do you guys double your bass sounds?
--Phil Oakey
tekkentool
Real name: Steve
Post by tekkentool » Tue Nov 09, 2010 12:15 pm
Yes plenty of times, to answer your question.
Pretty much all the time.
aeon
Post by aeon » Wed Nov 10, 2010 12:36 am
I tend not to layer bass sounds. I like the purity of a VCO mono, the sound of an articulated physical model, the expressivity and sound control of a virtual modular patch, as well as the cut and percussive snap of an FM doing electronic sounds (as opposed to that 80s pop/pluck/slap-string stuff).
cheers,
Ian
Erotic Cabaret
Real name: Tyler
Post by Erotic Cabaret » Wed Nov 10, 2010 2:51 am
Fair enough, Aeon. I guess I would say I'm the same, I just wondered how many people were layering.
--Phil Oakey
tim_m
Real name: Tim
Gear: Access Virus KB (x2), C
Akai AX-80
Juno-60
Ensoniq SD-1
Electribe ESX
Lots of guitars
Band: Trace-on.
Post by tim_m » Thu Nov 18, 2010 10:46 pm
tekkentool wrote:I like the real bass/synth bass dynamic. E.g David bowie's let's dance.
Is that a synth bass? I was thinking that it was a electric bass through a EH Bass Microsynth. I can get pretty close to that sound with the Microsynth.
tekkentool
Real name: Steve
Post by tekkentool » Thu Nov 18, 2010 11:56 pm
I always thought it was an electric bass layered closely with a Synth bass from another synth.
tim_m
Real name: Tim
Akai AX-80
Juno-60
Ensoniq SD-1
Electribe ESX
Lots of guitars
Band: Trace-on.
Post by tim_m » Fri Nov 19, 2010 7:35 pm
Upon some Googling, you are correct. The bassist, Carmine Rojas, mentions it in this Spanish language article.
