Hi guys, I have a 1202 Mackie and now purchase a Behringer 1832fx. So the question is - how to connect them correctly with each other so I could use them as one? I'm not gonna mix with them,only using as a putchbays for my synths.
Thanks
connecting two small mixers
- Z
Re: connecting two small mixers
I'd use the Mackie as your MAIN mixer and the Behringer as a SUB-MIXER. Take the main outs from the Berhinger and run them into one of the Mackie's AUX return inputs or the last stereo input (11&12).
Why?Z wrote:I'd use the Mackie as your MAIN mixer and the Behringer as a SUB-MIXER.
Z wrote: Take the main outs from the Berhinger and run them into one of the Mackie's AUX return inputs or the last stereo input (11&12).
XLR or Jack main outs? And It is also interesting why ''UX return inputs or the last stereo input (11&12)''? I know there are different signal levels or something?
- Z
Because Behringer mixers are noisy from my experiences from them and you want to be able to control that noise as much as possible.philip wrote:Why?Z wrote:I'd use the Mackie as your MAIN mixer and the Behringer as a SUB-MIXER.
For example, plug your least used instruments into the sub-mixer and "ride the fader" (or knob in the case of the Mackie) whenever sound is coming from these lesser used instruments.
Main jacks are fine.philip wrote:Z wrote: Take the main outs from the Berhinger and run them into one of the Mackie's AUX return inputs or the last stereo input (11&12).
If you're needing to "ride the fader" of the sub-mixer input, it might be best for it to run into the Mackie's 11&12 inputs so it will be easier to mix with that knobin line with the other inputs rather than the AUX return knob which is not as accessible.
