Help me recreate this patch!
kungfugeek
Long story short, I've been asked to play a gig with a band that I haven't played with in 15 years. I used a delay on the effects loop on my Rhodes and I'm trying to reproduce it. I think I may have used a Korg A3 preset, but I can't be sure. I plan to use Ableton as my effects host, so I have those plugs as well as several UAD plugs to work with. What do you guys think? How do I get close to this?
- Stab Frenzy
Re: Help me recreate this patch!
Bring up a Rhodes patch in Electric, add delay, add reverb, done.
- garranimal
Sounds like a double delay. Two different beat values playing off each other. I'm hearing more of the delays on the right side and dry on the left. Quite a nice effect.
kungfugeek
Do you think the first delay is then sent to another delay? Or rather the dry signal is sent to two different delays with different times?
- garranimal
Probably running the two delays in parallel, although trying it in series may also be interesting.kungfugeek wrote:Do you think the first delay is then sent to another delay? Or rather the dry signal is sent to two different delays with different times?
