Whoever said the DBX 266XL compressor is bad is lying!
squatski
Post by squatski » Fri Jan 13, 2017 6:02 pm
maybe you were just using it the wrong way! when you use it as a parallel compression, with the fastest attack/release setting and you're making dirty boombap beats, this compressor is the dogs danglers! yeah so it was under £100. but it's so disgusting on drums that it's under-rated in my opinion. It should be up there with the dirt box compressors hall of fame along with the alesis 3630!
discuss.
Real name:Tomas Mulcahy
Re: Whoever said the DBX 266XL compressor is bad is lying!
Post by madtheory » Fri Jan 13, 2017 10:02 pm
It's not bad, it's utilitarian. It doesn't do anything that you couldn't do with any other run of the mill compressor. I guess the gearslutz frown on it though :)
Yekuku
Gear:dk'tronics speech synthesizer :P
Post by Yekuku » Fri Jan 13, 2017 11:51 pm
I am interested in colorful compressors, Is it that good ?
Can you post an example ?
It is all about sharing...
squatski
Post by squatski » Sat Jan 14, 2017 2:06 am
madtheory wrote:It's not bad, it's utilitarian. It doesn't do anything that you couldn't do with any other run of the mill compressor. I guess the gearslutz frown on it though :)
lol if it's not a $9000 and up compressor with valves/tubes in they're not interested :lol:
seriously though before I bought it I was trying to find some reviews on it, first google searches are about 5 hate threads from the gearslutz team haha.
of course if I had the money I'd buy something like the drawmer 1960 or even just the DL241! but I just thought I'd give a run of the mill compressor the benefit of the doubt and found it actually suited to the style of music I did!
@ Yekuku yeah it deffo colours the sound. I'm no expert / connoisseur or something but it just has this mid range squish squash about it. hard to describe. I'll do a demo of it soon
Post by madtheory » Sat Jan 14, 2017 5:28 pm
Good choice, the Drawmer is over rated imo. I don't think they ever made a decent compressor. They got their rep from the gates.
Gear:Eurorack, RYTM, Ultranova, many FX
Post by Stab Frenzy » Sun Jan 15, 2017 5:24 am
squatski wrote:maybe you were just using it the wrong way! when you use it as a parallel compression, with the fastest attack/release setting and you're making dirty boombap beats, this compressor is the dogs danglers! yeah so it was under £100. but it's so disgusting on drums that it's under-rated in my opinion. It should be up there with the dirt box compressors hall of fame along with the alesis 3630!
discuss.
Try the RNLA, it'll blow your mind.
