I'm thinking of adding an affordable analog synth to my set up and a Juno 106 seems to be the only option within its price range, say 300 euro's. I'm using Logic, Reaktor and Massive for just about everything but I miss something that sounds really analog, so... I had the Ion a few years back and used it mainly for pads, which it did great. I searched some You Tube video's on the Juno and they seem pretty awesome for pads and basses! But can a Juno go much further than that? What about all the spacy tweaked stuff out there?
The specific sound I'm looking for is that of Substrata (Biosphere): songs like Poa Alpina and Chukhung have a synth in them that sounds absolutely great, and if it were a Juno 106, I'd buy one for sure!
Any advice?
Thx
Juno 106?
- Pro5
- Expert Member
- Gear: Prophet 10 Rev 4 | Prologue 16 | JD-800
Re: Juno 106?
Easy way to check if it was a juno 106, listen carefully to the songs and see if you can hear the voice chips failing
- aeon
Re: Juno 106?
Go for a Roland Juno-60 instead.
Or a whole other flavor such as a SCI Prophet-600.
The 106-chip-failure will bite you.
cheers,
Ian
cheers,
Ian
- braincandy
- Retired Moderator
Re: Juno 106?
Buying a 106 is just like waiting for an accident to happen. Unless you absolutely know that all the voice chips work properly and that everything else works properly, I would avoid it. If you really want a Juno, I'd recommend the 60, as Aeon said.
As far as "spacey" and "tweaked-out"--you can do that with a lot of synths as long as you have a decent effects unit. The Juno alone won't provide that.
Fender Blacktop Jazzmaster | Squier CV Duo-Sonic | e6400 Ultra | Blofeld | a bunch of effects
ned-ryarson
Re: Juno 106?
and you'd be doing really well to bag one for 300euro....
for complex sounds you need to go for something with a lot of routing options, (prob not vintage then) and plenty of experimentation with fx and pluggins.
to beef/analogue the sound up you could run, say a VA, through an analogue pedal of some sort...
i learned that trick here and it works a treat
- pflosi
Re: Juno 106?
+1 for juno6/60
besides the chip issues, they sound better. no eg pwm on 106. digital egs on 106.
