Most affordable vintage synth
psionic11
- Gear: -Fusion 8HD/6HD, Micron, X guitar, VFX-SD
-Ex5r, WSA1r, DD65, Performance Pad
-BCF, FCB, ExpressionMate, VF1, BC3
-(past) Juno 106, DW8000, Fantom Xa
Let's just say, until I can afford an Andy, I wanted to get a vintage synth off of ebay. What would your recommendations be? Here are the conditions:
1) under $200
2) at least 8 voice polyphony
3) self-oscillating filter
4) knobs to twiddle live
5) velocity and aftertouch sensitive
6) decent built-in FX (reverb, chorus) a plus
1) under $200
- CfNorENa
- Gear: SEM | SH-2 | Prophet 5 | MKS-70 | Microwave XTk | Kronos || AD 202 | El Capistan | DP/4 | Eclipse | Rumour | PCM90
Re: Most affordable vintage synth
If you find a working synthesizer that meets all six of your conditions
, you'll deserve a medal
I think the closest you'll get is an Akai AX-80 (but I don't know if this meets condition #3, and it only meets the first half of condition #5). If you can forego condition #4, then you might just be able to find a tattered Roland JX-10 for somewhere in your neighborhood (but not $200). But this is an idle exercise. I don't think you'll find everything you want for under $200. Would be more than happy to be proven wrong!
Good luck.
Good luck.
- Raiven
- Gear: See Signature.....
- Band: Eventyde
Stick to reality and save up for a while longer.
Korg M3 (Fully Loaded), Blofeld Keyboard, MPC 2500 LE, (Monomachine), Logic Studio 8, Live 6, FM8, Absynth 4, Predator, Alpha3, Korg Legacy Collection, (Shioitor), Drumazon, Nepheton, Stylus RMX
http://www.myspace.com/eventydejams
I noticed you didn't explicitly say analog, so maybe if you drop 3 & 4, and raise the price just a bit, the Ensoniq SQ-80.
It's really easy to edit, and I've found that self-oscillating filter and polyphonic aren't as compatible as you'd think, especially if you have a sine-wave waveform.
--Solderman no more.
- Z
Nothing like that exists. Not many "vintage" synths have velocity/aftertouch or effects. Some of the mid/late 80's had touch sensitivity and many have built-in chorus, but none with reverb.
The closest you might be able to get in that price rance would be:
Akai AX-60, AX-80
Roland JX-3P, JX-8P and (maybe) JX-10.
Now you should be able to find a used VA with most, if not all, of your requirements.
Akai AX-60, AX-80
- Stab Frenzy
Except for the velocity and aftertouch a Poly-800 mkII with the moog slayer mod ticks the boxes. You said 'knobs', so two knobs counts right?
- RobotHeroes
- Gear: a toothed wheel that engages another toothed mechanism in order to change the speed or direction of transmitted motion
8 Stylophones + kaossilator
"*Automatic Gainsay, you ignorant slut." - Primal Drive
"thanks guys. RobotHeroes, your avatar is the single most important thing on this website. ever. it reminds me that the world actually can be a good place." - rjd2
- Z
Ah! I forgot about Korg. Although they only have one data slider, you might could find a DW-8000 or 6000 for around $200.
Blimey, that's a tricky one. Again, picking up that you didn't specify analogue, what about a Kawai K1? It's got a kind of joystick for realtime tweaking, the sounds are, well, okay. And it's often dirt cheap. I know it's velocity sensitive and has aftertouch, but I don't think it has built in effects. It's a very long time since I've used one!
Read my retro synth and computer musings on Bleep*Star
- shaft9000
- Real name: Dave
- Gear: Whips chains and a contract.
maybe if you get in a time machine and go to 1992 you'll find what you're looking for.
But 'vintage'+Ebay these days almost never = under $200
look elsewhere: garage sales, craigslist etc
.svc350.memotron
.svc350.memotron
- Sir Nose
- Real name: Bob
- Gear: Machinedrum, Octatrack, Moog LP, x0xb0x, Elka Solist 505, Simmons SDS-400
I just noticed that you did not say analog. Vintage analog with all of your criteria does not exist.
How vintage?
How about an E-mu command station XL-7?
Usually over $200, but a PX-7 went on the bay last month for $180
How vintage?
all that is good is nasty
- Electroluver
- Gear: MS-20, M-500, Polysix, PAiA 4700, ROL309, C64 MSSIAH, JX8P, K2000J, SY-1010.
- Band: DJ NAMELESS
Trust me, don't buy a Kawai K1, it's a total POS. For $200, your best bet is an Alpha Juno 2 (velocity sensitive, MIDI, analog, polyphonic) You would need a PG-300 for the knob twiddling, but the alpha dial is quite useful.minty wrote:Blimey, that's a tricky one. Again, picking up that you didn't specify analogue, what about a Kawai K1? It's got a kind of joystick for realtime tweaking, the sounds are, well, okay. And it's often dirt cheap. I know it's velocity sensitive and has aftertouch, but I don't think it has built in effects. It's a very long time since I've used one!
- balma
- Real name: Mauricio
- Gear: DSI Tempest/Prophet 08/Roland V-Synth/Ensoniq Fizmo/E-mu MP7-XL7/Electribe ESX1/Radias/Waldorf MicroQ
Or check every garage sale on US from coast to coast.Raiven wrote:Stick to reality and save up for a while longer.
From time to time a dusty Minimoog arises from dust to be sold on $100 on a grandma's garage sale
https://soundcloud.com/balma
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
good luck finding vintage goodness under $200.
skimming thru the first two pages of ebay brings up these for (at that time) less than $200:
Roland JX3p
Yam SY85
Alesis micron
Ensoniq ESQ-q
Yam CS1x
Casio CZ101
(no flame intended) If you find an OB-8, Synthex, PPG, etc for two bills, LET US KNOW !!!!
Roland JX3p
Yam SY85
Alesis micron
Ensoniq ESQ-q
Yam CS1x
Casio CZ101
- Confucius
- Confucius
psionic11
The Korg DW8000 came to my mind as I posted. I used to have one, and the delay and chorus are fine, and the one slider can be set to a parameter, so that would work, esp since it did have velocity and aftertouch IIRC.
