Analog Sequencers - Oberkorn vs. Evolver
- thinkingbeat
- Gear: Korg Polysix, Waldorf Micro Q, Roland JP-8000, Korg Prophecy, Waldorf Nave
I am thinking of getting into analog sequencing and have been looking at standalone sequencers such as Analogue Solutions' Oberkorn or Synthesizers.com's Q960.
Then I realized the DSI Eveolver desktop has a 16 x 4 step sequencer on it with a lot of control and routing options. It's more affordable, and it has a pretty decent synth on board. So - any drawbacks to the Evolver's sequencing - anything the others can do that the Eveolver cannot?
- meatballfulton
- Gear: Logic Pro X
Re: Analog Sequencers - Oberkorn vs. Evolver
Most step sequencers let you choose the gate length per step but the Evolver gating is fixed at 50%. That means no legato phrasing is possible so no portamento
One very cool feature is the sequencer can modulate the sequencer clock itself
so you can create sequences that speed up or slow down as they play.
When sequencing MIDI gear you you can output these controllers in addition to notes (one controller per row): velocity, aftertouch, mod wheel (CC#1), breath controller(CC#2), foot controller (CC#4). You can also output just controller and no notes if you like
- pflosi
Oh yes, IMO the most important one on analog seqs: hands on controlthinkingbeat wrote:So - any drawbacks to the Evolver's sequencing - anything the others can do that the Eveolver cannot?
- thinkingbeat
pflosi wrote:Oh yes, IMO the most important one on analog seqs: hands on controlthinkingbeat wrote:So - any drawbacks to the Evolver's sequencing - anything the others can do that the Eveolver cannot?
- pflosi
well, not for every step. you have to go through the menu to get to the right one. that's not what i call on the fly...
- pflosi
also have a look into:
doepfer MAQ 16/3
manikin schrittmacher
SND SAM 16
doepfer MAQ 16/3
SND SAM 16
- Sir Nose
- Real name: Bob
- Gear: Machinedrum, Octatrack, Moog LP, x0xb0x, Elka Solist 505, Simmons SDS-400
Also, the Evolver is only internal. The sequencer can not control other gear.
all that is good is nasty
evolver can send midi note out!
the evolver seq is mainly strong in the synth itself with its many destinations
to outside gear it looses this flexibility quite a bit
if you have other synths or a modular, you going to be better of with a standalone seq. and than your budget will play a role
also do you want a midi seq or cv/gate or the combination?
- pflosi
well that kills it for the OP
edit: well in this case not really
- prinsen
- Gear: Blokey, MS10, Matrix-6, Kult, TR-808, Tokai Jazzbass, DIY modular + fx, amps and mics.
I've seen this claim quite a few times here on VSE, but according to the Evolver manual the sequencer can be routed to the midi output to modulate a limited number of midi parameters. Eg. MIDI note number, MIDI Velocity, MIDI Mod Wheel and MIDI Pressure.Sir Nose wrote:Also, the Evolver is only internal. The sequencer can not control other gear.
- meatballfulton
- Gear: Logic Pro X
As mentioned in my reply this is incorrect.Sir Nose wrote:Also, the Evolver is only internal. The sequencer can not control other gear.
What menu? You press ONE button to pick the 8-step row you want and start turning the knobs.pflosi wrote:well, not for every step. you have to go through the menu to get to the right one. that's not what i call on the fly...
You might want to look around for reviews of the evolver sequencing other gear. I seem to remember it had some really strange quirk like it sequenced external gear a few notes lower than programmed like a E would be a C, etc. I can’t recall exactly but it seemed to make it a bit unusable or at least awkward to sequence other gear. Internally it can be beat, it’s an amazing sequencer within the confines of just sequencing just the evolver.
hello darkness, my old friend
- meatballfulton
- Gear: Logic Pro X
---The MIDI note numbers are offset by one. MIDI note 0 to the Evolver sequencer means play no note at all. When programming pitch values you have to set them one higher than the actual MIDI note number you want to play. If you really want MIDI note 0 to play you have to program that step as 1, etc. This is mentioned in the manual BTW.otto wrote:You might want to look around for reviews of the evolver sequencing other gear. I seem to remember it had some really strange quirk like it sequenced external gear a few notes lower than programmed like a E would be a C, etc.
---The parameter resolution for sequencing internal pitches is a quarter step (i.e. you can play a note that's halfway between C and C# if you like, very cool for experimental music) but when sequencing MIDI the resolution is half steps because MIDI note numbers don't support any finer pitch resolution. Luckily, if you have oscillator pitch as a destination and you switch the destination to MIDI note number (or vice versa) the sequencer row gets cleared out automatically.
BTW you can program one or more rows to drive MIDI while using the remaining rows to play the internal synth as well.
