First Drum Machine?
colorbars
- Gear: Juno-60, ESQ-1, Mopho, Micron, Poly 61, MS2000R, DX-7, DX-21, M-VS1, ES-1 mkII, Monotron, ESI32, TR-505, EA-1
First Drum Machine?
I've decided it's time for me to get a drum machine, but i'm not too knowledgeable in that area. What would be a good reasonably priced drum machine that's fairly easy to use? I'm looking for something i might be able to scoop up on eBay for a good price.
- braincandy
- Retired Moderator
Re: First Drum Machine?
Are you more interested in acoustic or electronic sounds? Also, what is the maximum you can spend?
Fender Blacktop Jazzmaster | Squier CV Duo-Sonic | e6400 Ultra | Blofeld | a bunch of effects
- meatballfulton
- Gear: Logic Pro X
Also what other gear do you already have?
colorbars
Acoustic and electric sounds if possible
as for other gear.... Esq-1, ms2000r, micron, korg poly 61, dx-21 etc
colorbars
Under $100 if possible, not looking for anything too fancy
Dr-660
Sh-101, tb-303, Juno-6, Jx-3p, TR-808, TR-707, TR-727,Oberheim DMX - Tascam m-312b + ghetto effects
- Syn303
- Expert Member
- Gear: Quite a bit...
- Band: Syn303
Roland TR-505 possibly the 626, also any of the Yamaha RX's 11, 17, 21, 21L they are all quite cheap to buy.
- Voodoo Ray
- Gear: ●
Akai
Waldorf
Roland
Yamaha
TR-505/626.
- speak_onion
- Real name: Dan
- Gear: Octatrack, G2 Engine
- Band: Speak Onion
If you can handle working with samples, the Korg ES-1 loaded with samples of any drum machine you want (they are all easily findable on the internet) will do you, plus give you a really nice sequencer and lots of manipulation capabilities. It's what I wish I had as my first drum machine.
blavatsky
- Gear: MV8800, Sub37, Integra 7, Mininova, Fusion, Biscuit, TimeFactor, SP-555, SP-404, SPD-SX
- Band: Blavatsky
shameless plug, I have an es-1 for sale in the classified. It's a great machine, only selling because I got an ESX-1.
the sampling gives you endless flexibility + decent effects + great sequencer.
- meatballfulton
- Gear: Logic Pro X
The TR-505/626 fits your budget but are dated soundwise, no electronic drum sounds. Programming backup only via a tape interface no MIDI dumps
I would look for a used Alesis SR16 or a Boss DR550/660. If it matters, the Boss units only have MIDI IN so you can't back up your programming at all
or use it as a clock master.
- space6oy
i agree w/ the ES-1 being a great choice. more or less the ER-1 but you can load it w/ better sounds. easy to program, up to 64 step sequences, nice built in effects.
SR16 also IMO has pretty great live drum type samples.
- krzeppa
- Real name: Kevin J
- Band: Where the Embers Fall
My old roommate from college had one of these. For the price, I think it would be good a choice for a first drum machine. I fooled around with it from time to time, and it seemed pretty easy to work with.speak_onion wrote:If you can handle working with samples, the Korg ES-1 loaded with samples of any drum machine you want (they are all easily findable on the internet) will do you, plus give you a really nice sequencer and lots of manipulation capabilities. It's what I wish I had as my first drum machine.
- speak_onion
- Real name: Dan
- Band: Speak Onion
Agree. Definitely put some SR16 samples in your ES-1.space6oy wrote:SR16 also IMO has pretty great live drum type samples.
