Analog Poly Synth
imperets
Analog Poly Synth
Post by imperets » Mon Apr 18, 2011 10:30 pm
I'm looking to buy a new synth, and it needs to meet the following criteria:
- 100% analogue
- polyphonic (at least 4 voices)
- under $1000
- has a keyboard
- has MIDI
- has at least 2 ocsillators per voice
The first 3 criteria is an absolute must; the last 3 I'm flexible on. All ideas will be appreciated.
PS: not interested in Juno 106
Z
Re: Analog Poly Synth
Post by Z » Mon Apr 18, 2011 10:52 pm
The closest contenders I can think of are:
Akai AX60 - meets all criteria except only one VCO per voice.
Akai AX80 - dual DCOs
Korg DW-8000 - dual DCOs
Korg PolySix - single VCO, no MIDI
Korg Poly 61M - dual DCOs
Roland JX-3P, 8P and 10 - all dual DCOs
Roland Juno 60 - single DCO with sub-osc, no MIDI but you can get a MIDI to DCB converter
SCI Prophet 600 - meets all criteria if you can find one under $1K. For a while, they were in the $800 ballpark. I couldn't find any completed listings on eBay.
Projectile
Post by Projectile » Tue Apr 19, 2011 12:46 am
You're going to have a h**l of a time meeting all of those criteria for under a grand.
Real name: Unpronounceable
Band: Eridani V
Post by Ashe37 » Tue Apr 19, 2011 1:00 am
DW-8000 is obviously not 100% analogue.
technically, if you're looking for "100% analog" you would be saying you dont even want a microcontroller scanning the keys, which excludes anything in the $1000 range and means you wont even have patch memory.
If you want something *new*, then a Tetra + MIDI controller is the obvious choice.
Other suggestions include the Roland JX series as Z mentioned, and the Oberheim Matrix 6r, which usually runs about $600. Of course, those aren't "100% Analog", they are DCO analogs...
imperets
Post by imperets » Tue Apr 19, 2011 7:30 am
i've been thinking about picking up a tetra + controller... hmm
Band: Eridani V
Post by Ashe37 » Tue Apr 19, 2011 9:14 am
imperets wrote:i've been thinking about picking up a tetra + controller... hmm
If you get a really good controller like a Novation Remote (I have a Remote Zero) you can set up controls to be able to do much deeper editing than you can on the front panel of the unit. I made a template for my Mopho like the second day i had the Remote.
CfNorENa
Post by CfNorENa » Wed Apr 20, 2011 4:22 pm
imperets wrote: - 100% analogue
- under $1000
- has a keyboard
- has MIDI
Another vote for the Prophet 600. They do still pop up for around $1000, and it definitely meets the other criteria as well. Luscious, vintage analog sound. Probably the last "bargain" in the vintage poly analog market...
krzeppa
Real name: Kevin J
Band: Where the Embers Fall
Post by krzeppa » Wed Apr 20, 2011 7:03 pm
+1...this would be the way I would go. The Tetra is a great synth, and the price is great for something brand new (which means you should theoretically have less to worry about in terms of maintenance costs). Team that up with a good midi keyboard....and I like Ashe's recommendation of te Remote, and you have a very powerful synth right in your price range.
TheKeytarist
Real name: Joseph
Post by TheKeytarist » Thu Apr 21, 2011 2:15 pm
The prophet 600 is, of course, vintage, and that may mean higher maitenence bills. How ever, newer analogs may have more features, but are said not to sound as warm as their vintage counterparts. The prophet 600 seems to have most of the features that the tetra has, plus it features more hands on controlls. The tetra, still, could work, that is, paired with the novation controller. Just my thoughts...
"A learned blockhead is a greater blockhead than an ignorant one."
— Benjamin Franklin
:keys1: :drums: :keys2:
imperets
Post by imperets » Mon Apr 25, 2011 4:51 pm
Is there a "boutique" alternative along the lines of Vermona Perfourmer, but one that's still in production?
Sir Nose
Real name: Bob
Post by Sir Nose » Mon Apr 25, 2011 5:09 pm
I was gonna say Jomox Sunsyn, but it looks like they stopped production.
http://www.jomox.de/product_details.php ... duct_id=14
all that is good is nasty
Z
Post by Z » Mon Apr 25, 2011 7:25 pm
Sir Nose wrote:I was gonna say Jomox Sunsyn, but it looks like they stopped production.
And is WAY more than $1K.
imperets
Post by imperets » Mon Apr 25, 2011 8:11 pm
I've been also considering one of the following Roland synths: JX8P+PG800, JX-10+PG800, MKS-70 or similar. How do they compare to Prophet 600 or Tetra? How do they compare to Juno 106? My problem with 106 was that it only had one oscillator. Will I be happy with a JX8P (or similar) that it has 2 ocdillators? I'm aware of the crappy interface of the XP and the likes, I'm mostly comparing the quality of the sound. I already have the following synths in my setup: Moog little phatty; Access virus Ti; Nord Modular; Vermona Drm1.
What adjectives would you use to describe the sound character of the mentioned above Roland synths?
antilles
Real name: David
Gear: Virus C, String Melody II, Triton, MS-20, M1, Juno-60, Paraphonic 505, SH-09, VK-09, JD-800, JD-990, Pro One, CS-30, SY-1, TX81Z
Band: Antilles
Post by antilles » Tue Apr 26, 2011 9:29 am
The JX8P is good but sounds a bit dull compared to the Juno's IMO. There's also the Oberheim Matrix 6, though it's not 100% analog. (Digital envelopes and modulation).
I'd say the Tetra has the fattest and most analog sound for a polysynth in that pricerange. However its only 4 voice polyphony, which is a b***h.
aeccoin
Post by aeccoin » Tue Apr 26, 2011 9:22 pm
If I were you I would go for:
- Sequential Prophet 600
- Roland Juno 106
- Korg Poly Six (or Mono/Poly!)
- Oberheim Matrix 6
- Roland JX3P + PG200
- Roland JX8P
Personally I would hold out for a Prophet 600, 106 or Matrix 6. I picked up a Juno106 for $200! And I've recently seen Prophet 600's go for $600-$900, Matrix 6's sometimes pop up for $400.
It's worth the wait.
I also have a Tetra, it's cool but you'll be wishing you got something with a keyboard and more control.
Cheers!
M
