DIN SYNC splitter
FrankenZappa
DIN SYNC splitter
I find myself in need of something to split a din sync signal for my x0x's. What are your favorite devices to accomplish this task?
OntarioHydro
- Band: {}[]<>[]{}
Re: DIN SYNC splitter
Korg KMS-30 does the trick
I built my own:
Not that difficult, really. I bothered to make terminals inside for each side of the leads, but that only takes a little more time. Passive split works just fine, even under battery power.
--Solderman no more.
FrankenZappa
Cool! I didn't know that a passive split worked. Thx for the knowledgeSolderman wrote:I built my own:
- Sir Nose
- Real name: Bob
- Gear: Machinedrum, Octatrack, Moog LP, x0xb0x, Elka Solist 505, Simmons SDS-400
all that is good is nasty
I like that idea of using a switched 1/4 inch jack to override the clock. If you were trying to actually sync with that though, you'd constantly be dealing with 24X your intended frequency for crotchet lengths.
