Hi,
looking for some advice on samplers.. my main use for it is I want to sample sounds from my jd800 so I dont have to drag that beast out to shows anymore.
only requirements are that it has a keyboard (no rack units), is relatively light/portable, at least 2 part multi-timbral and the less expensive the better.
I currently have a mirage, but its a little too lo-fi sounding and just about as heavy as the JD800
just so you can get an idea of what I've been considering: roland s-50, casio fz-1, korg microsampler(?)
advice is much appreciated!
trying to find the right sampler
- meatballfulton
- Gear: Logic Pro X
Re: trying to find the right sampler
microSampler is not designed to do multi-sampling...not what you want at all.
Roland W-30, Ensoniq EPS, EPS-16 and ASR10 should be on your list.
To avoid: Roland S-10, Akai X7000 both using QuikDiscs; Korg DSS-1 is way too heavy though I've seen them go for $99!
Maybe consider turn of the century workstations like Trinity, Triton, Fantom, Motif although these will cost more. No floppies, less wear and tear, larger sample memory, usable synths and FX.
- ianjhicks
- Gear: 808, 707, pro one, juno 60, jx3p, juno 106
- Band: Soft Metals
kinda worried the ensoniq boards and any workstation might be on the heavy/bulky side which is what I'm trying to move away from w the jd800.. whats up with the roland w 30?
- meatballfulton
- Gear: Logic Pro X
The W-30 is based on the S-50, as the name implies it's considered a workstation (has a sequencer). It was the last of the Roland sampler family to come with a keyboard.
Do you have other keys that could be used to drive a module? You could recreate your JD800 sounds in a JD990 rack...not sure about current pricing on those. Of course you can find sampler racks dirt cheap, a local dealer has an Akai S2000 for $50...that's just crazy.
Good luck.
Good luck.
- madtheory
- Real name: Tomas Mulcahy
Personally I think you'd be better off with a laptop running Kontakt and Autosampler- that will give you a very accurate rendition of the JD-800 sounds, and it's painless because it's automated. Get a light USB controller and you're sorted.
- Vides7
- Real name: Dan
- Gear: EnSoniq Asr10
Emu SP 1200
Roland S 760
Roland juno 106
Roland Mks 80
Roland Mks 70
Yamaha FSR1
Oberheim Xpander
Marion Msr2 - Band: Paperjam
Hi Wonderful people,
I was wondering how much it cost now to find a Fairlight CM II X on market ?
Thanks for info
Vides 7
Thanks for info
Vides 7
VortexWorks "Creators of Sound and Music Universes "
- madtheory
About EUR5000 to EUR8000 depending on condition, provenance and board REVs. Excludes shipping.
