Korg MS 20 step sequencer compatibility
UrbanSynthesis
Post by UrbanSynthesis » Sun Dec 09, 2012 6:18 pm
Hello there
Iv been reading a lot about the Hz/V that the korg MS 20 uses vs the common oct/V scaling, my goal is to get a step sequencer connected with the Korg ms 20. The korg sq-10 was specifically tailored for this, but I was wondering if there are any other options, or maybe a setup with which I could utilize other analogue sequencers. Korg MS02 INTERFACE is promising, however Im not sure if it does what I think it does which is being able the korg Ms 20 to be compatible with oct/V scaling devices. Im looking for more knowledgable persons opinion like yours.
Thanks!
Z
Re: Korg MS 20 step sequencer compatibility
Post by Z » Sun Dec 09, 2012 7:37 pm
Future Retro Mobius offers both voltage scalings.
phesago
Real name: Douglas
Gear: tech nine, bag of coke, an erection and a hostage
Post by phesago » Sun Dec 09, 2012 7:44 pm
Z is correct. The mobius will work wonders for you. Coincidentally, I have one for sale in the For Sale forum here :D
PM me if youre interested
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Sun Dec 09, 2012 8:25 pm
Also the old Kenton midi/CV boxes convert between all kinds of CV's, right?
syntheticsolutions
Real name: Ryan
Gear: Rhodes 78 Mk2, Jupiter 4, Juno 6, VP-330, Prophet 600, Pro-One, CS-30, CS-50, Polysix, MonoPoly, MaxiKorg, 770, Opus 3, Odyssey mk3, Machinedrum
Band: Lunar Modular
Post by syntheticsolutions » Sun Dec 09, 2012 8:26 pm
You could also use a sequencer such as the Doepfer Dark Time however, you would need a CV convertor such as a Kenton Pro or the Korg MS02 interface. The dark time is fantastic, I have been playing with it all day :)
Psy_Free
Gear: Synths 'n' stuff.
Band: Klangzeit
Post by Psy_Free » Sun Dec 09, 2012 10:54 pm
A Kenton Pro Solo Mk II will work & is more readily available (& way cheaper) than an MS-02 (which will do the job also).
Bandcamp 1
Bandcamp 2
Soundcloud
RetroSynthAds
Post by RetroSynthAds » Sun Dec 09, 2012 11:43 pm
Double plus good what Psy_Free said.
A Kenton pro solo mk2 attached to an ms20 is a wonderful thing. And you will find other uses for the Kenton - its like the swiss army knife of my studio. You can always use a few more of them.
d**k Martini
If you are bored... check out my blog: http://retrosynthads.blogspot.com
analoglsd
Real name: Lance
Gear: Buchla Music Easel, TE OP-1, Korg MS-20, Yamaha RS-7000, Effects Pedals
Post by analoglsd » Mon Dec 10, 2012 12:37 am
You should really consider buying the Mobius that phesago has for sale.
The Mobius is a very flexible sequencer and the fact that is has clock out and DIN Sync out makes it even more so.
Also, you're not likely to find one cheaper than what he's asking for his.
If I didn't already have one, I'd be buying it.
space6oy
Post by space6oy » Mon Dec 10, 2012 12:57 am
+1 and i have two of 'em. dedicated to my MS-10 & 20 but they'll work with anything and are fantastic sequencers.
pflosi
Post by pflosi » Mon Dec 10, 2012 10:17 am
Another work around exists right out of the box: the "total" or "VCO Freq" inputs will both approximate a 1V/oct response with the respective attenuator knobs all the way up... That doesn't disconnect the keyboard though, which can be an advantage as well (instant transpose).
space6oy
Post by space6oy » Mon Dec 10, 2012 9:18 pm
$550 OBO
haj
Post by haj » Mon Dec 10, 2012 11:47 pm
Elektron A4 is new alternative especially for price/feature ratio considered. It can also do s-trigger/gate.
pflosi
Post by pflosi » Tue Dec 11, 2012 9:35 am
haj wrote:Elektron A4 is new alternative especially for price/feature ratio considered. It can also do s-trigger/gate.
But it doesn't do Hz/V, right? That would really be great...
BTW, apart from the V/oct trick with the VCO modulation inputs, the MS20 can also convert anything to S-trigger on board with the ESP (only a trigger resulting though, no gate unfortunately).
Post by Stab Frenzy » Tue Dec 11, 2012 11:53 am
It does both.
pflosi
Post by pflosi » Tue Dec 11, 2012 2:40 pm
Really? Awesome! That makes up a little bit for the lack of midi note out I've ranted about (which you clearly didn't like) ;)
