Cheap old sampler
Bloodonmyface
Cheap old sampler
Post by Bloodonmyface » Mon Jul 08, 2013 10:39 pm
Hello all! I'm looking for a sampler similar to a akai s950 or s900. But I'm wondering if there are cheaper options . My requirements are to be able to transpose a sample across a keyboard, pitch shift and time stretch. Iv seen other akai s models for cheaper than the s950 but I can't confirm if they have pitch shift and time stretch. Also would be nice to have a adsr or Lfo. Also must be in a rack configuration as I'm low on space.
Plan to use it for ala skinny puppy/ministry type sample work. And want to thru some digital wave forms from a esq1/prophet vs for light synth work. Also doesn't have to be low bit sampler if there is a cheaper unpopular model like a 16 bit, would be fine.
Thanks for any info.
Also previous vse user here, been about 6 years. Great job to the web masters and contributors for keeping this site updated and looking good.
Jay200MPH
Gear: Currently active:
x0xb0x, MC-202, Microkorg, PSR-36, mini-KP, SA-5, JV-1010, S-760, CMU-800.
Sequenced in Impulse Tracker on a P233 w/AWE64+GUS.
Re: Cheap old sampler
Post by Jay200MPH » Tue Jul 09, 2013 1:20 am
Roland S7xx can do all that & has great filters too. They seem to go pretty cheap in the States.
I just picked one up but haven't had time to really explore it yet. Very cool piece of gear though. The full-screen video out feature is awesome!
Z
Post by Z » Tue Jul 09, 2013 1:40 am
I don't think there are any 12 bit samplers that do time stretch. I don't remember time stretch coming along until the mid/late 90s and by then all samplers were at least 16 bit.
Before that, we'd take our 12 bit loops and run them through pitch shifters like Korg DVP-1 and Yamaha SPX90.
plus321
Post by plus321 » Tue Jul 09, 2013 5:47 am
S950 can timestretch. I think TX16W can with Typhoon OS, but I'm not sure.
If you don't care that much about "lofi," try to find like an s2800 or something. I once got one for $20 when I was buying a case off a guy. S3000 series Akai are really cool. Definitely cool with the extra filter card, but still pretty cool without it. I think they can timestretch. I don't think E-mus had timestretching until e4s.
mpa1104
Gear: Finally, enough gear that exceeds the 150 character allowance. WooHoo - I qualify as an obsessed gear-head!
Post by mpa1104 » Tue Jul 09, 2013 8:31 am
Ensoniq ASR 10 will do time expansion and compression. You can also downsample to lower bit rates for lo-fi stuff. There was a rack version, but haven't seen one around for a while.
It doesn't matter if you don't like my personality, I have several more.
Post by madtheory » Tue Jul 09, 2013 12:38 pm
plus321 wrote:I think TX16W can with Typhoon OS, but I'm not sure.
Yup, it can timestretch. With Typhoon it's a much nicer box to use than an S950. Brighter, slightly harder sound.
But you can do all of that stuff and more with Kontakt. The SP1200 emulation sounds a lot like low sample rate on an S950 or TX16W.
Bloodonmyface
Post by Bloodonmyface » Tue Jul 09, 2013 4:38 pm
Thanks for all the advice! I looked into recomendations and a Roland s330 can be had for dirt cheap. Is it "usable" without having add on controllers and moniters? or is it worth paying a little xtra for an akai s series ?
I guess it comes down to ease of use as a stand alone unit, out of what was recommended.
Post by madtheory » Tue Jul 09, 2013 9:27 pm
Purely for ease of use, the TX16W with Typhoon beats most hardware samplers.
Jay200MPH
Post by Jay200MPH » Wed Jul 10, 2013 1:24 am
Bloodonmyface wrote:Thanks for all the advice! I looked into recomendations and a Roland s330 can be had for dirt cheap. Is it "usable" without having add on controllers and moniters? or is it worth paying a little xtra for an akai s series ?
I'm not 100% sure but I don't think the S330/S550 can do time stretch. They are a generation older than the S7xx but still very interesting instruments in their own right. (This video of an S330 was what got me looking into them in the first place - pretty cool stuff!)
The S330 won't have much RAM unless it's been upgraded. I imagine using one without a mouse & display would be a pain. You can plug in any old TV to its composite display port or an Amiga/etc. RGB monitor if you feel like building a simple cable. There are plans for a cheap PS/2 mouse adapter but it's a little more involved (including programming an EEPROM.)
It will load its OS off a floppy so make sure you either get one with it or have a computer with a floppy drive so you can write one (the OS image is kicking around, e.g. here - great site BTW!) The 330 and 550 can also run the Director-S sequencer which the later 700s can't.
All that said, if it's cheap enough just go for it! You can always use it as-is for the time being and get the rest of the add ons later, remember these were very high-end instruments when new.
Edit: here's a blog post with a 'review' and some great info on the S330. Read down into the comments too as he solves some of the issues he mentions and follows up.
Bloodonmyface
Post by Bloodonmyface » Wed Jul 10, 2013 5:09 pm
Cool thanks for the info guys n gals. I'll keep my eyes peeled for your recomendations. Im hoping to score one 75 bucks or under including shipping. It seems like a great time to buy a hardware sampler, prices for even an akai s6000 are like 300 bucks.
GameChanger
Gear: MPC60
Post by GameChanger » Wed Jul 10, 2013 10:54 pm
mpa1104 wrote:Ensoniq ASR 10 will do time expansion and compression. You can also downsample to lower bit rates for lo-fi stuff. There was a rack version, but haven't seen one around for a while.
Cheaper option is the EPS 16+ rack, which can downsample to much lower bitrates then the ASR10. I see them going for super cheap too, like $150 range. Its my favorite sampler by far.
Bloodonmyface
Post by Bloodonmyface » Thu Jul 11, 2013 8:59 pm
Ok kept an open mind and searched alot for a steal. It's not the Cheapest sampler but I got my money's worth.
Akai s5000 with expanded ram off local criagslist for 150 bucks. I am a happy camper :D
I just started rebuilding a small setup so I actually don't have anything with midi to control the akai s5000 yet. Been eyeballing some prices and looks like the cheapest smaller sized keyboard with midi is novation x-station, microkorg and Alesis micron. I would love something like a Yamaha sy22 but I just don't have the space.
Any advice on a smaller keyboard with midi thats usually found cheap please give me your thoughts and recomendations.
plus321
Post by plus321 » Thu Jul 11, 2013 10:15 pm
alesis q49
Jay200MPH
Post by Jay200MPH » Thu Jul 11, 2013 11:50 pm
Bloodonmyface wrote:Ok kept an open mind and searched alot for a steal. It's not the Cheapest sampler but I got my money's worth.
That sounds like a pretty good deal. Had a look at the S5000 on the VSE main site; I didn't realize those were so powerful! I like the DOS disks and WAV sampling. The removable keypad/screen is cool too (I have a primitive version of that for my Roland.) Nice score, you'll have fun with it!
tamla
Gear: Nord G2 Engine, Roland VariOS, custom Akai MPC2000XL, Akai S612, Korg TR-Rack, Korg Prophecy, Oakley Filtrex 2
Post by tamla » Fri Jul 12, 2013 10:45 am
^^^ I would have suggested an S5000, people are/were flogging them off v.cheap. I bought two the other month.
