if i had one synth question
i'll be purchasing an mpc soon
would it be best to buy a 16 multitimbral synth to sequence with mpc like the triton series or some other synth much more powerful but not multitimbral that i could sample
- megamanx
- Gear: nord lead2, roland sh101, yamaha cs5,mono/poly, sub37,Ms20, Chroma polaris,prodigy, esq-1, jx3p
- Band: Thieves & Co.
Re: if i had one synth question
well the tritons have their own sequencers and samplers, so it would make owning the mpc a bit redundant...unless you are crazy about the mpc interface or something...also depends on your budget...
triton was just an example because of it's multitimbral(ness?)
- megamanx
blofeld maybe...the virus series...
hit me up with some more suggestions
someone recommended the nord lead 2x but it only has 4 parts
What kind of sounds are you after? Is money an issue? If you need a really broad pallette, maybe a Roland FA-06, great price, too. Or an Access Virus TI2
money is kind of an issue, just takes longer to save up right.. a wide sound pallette is good. in the past with reason i'd always use synth sounds and real instrument sounds together.
Well, I think you'd be wise to check out the Roland FA-06, then.
better than a v-synth ?Hugo76 wrote:Well, I think you'd be wise to check out the Roland FA-06, then.
skunk3
- Real name: Vincent
- Gear: ESX, MPC 2500, EPS16+, TX16w, TX81z, Micro Q, Microbrute, Bass Station 2, MS-20 Mini, Nord Lead 2, Machinedrum, D-50, QS7.1, loads of effects...
- Band: Purplewave
The Korg Micro-X is like a baby Triton Extreme. It is utterly loaded with sounds but lacks a sequencer / sampler. It is 16 part multitimbral and pairs well with a MPC. I know from experience.
Nothing beats the V-Synthyamaha22 wrote:better than a v-synth ?Hugo76 wrote:Well, I think you'd be wise to check out the Roland FA-06, then.
But as skunk3 suggests, a Micro-X should be a nice solution as well.
if i was using the FA06 full 16 instruments and got them the way i wanted can you save that as a program or something?Hugo76 wrote:Nothing beats the V-Synthyamaha22 wrote:better than a v-synth ?Hugo76 wrote:Well, I think you'd be wise to check out the Roland FA-06, then.Well, actually, for your purposes, an FA-06 would be better. The V-Synth isn't a rompler, and limited polyphony will make for a limited multitimbral setup (be ware that multitimbrality is only present in the original V, there may be some limited solution in the GT, not sure).
- meatballfulton
- Gear: Logic Pro X
Yes, you can save it.
ColorForm2113
- Gear: tin cans and rubber bands
- Band: Me twiddling in the corner...
blofeld
that is an extremely powerful and versatile synth. I had a table top version, then wanted a keyboard and had both for awhile sold the desk top, then the keyboard to fund modular addiction now I miss it so I'll probably end up with another in the near future.
- nuketifromorbit
- Expert Member
Emu proteus 2000 series with expansion roms or perhaps the roland xv/jv series if your looking for something that can do both synthetic and acoustic sounds. I see a lot of people recommending the blofeld in this thread, but isn't the multi-timbral mode buggy?
