I currently only have the EZKeys String Machine library but I think there must be something better out there, right?
A good all purpose 70s string machine clone VSTi?
Hello. I'm looking an authentic sounding vintage string machine VSTi plugin. Something like the string synth heard here for instance would be ideal. What would you recommend? My budget is $30 but I might consider saving up for something pricier if it's really good.
Re: A good all purpose 70s string machine clone VSTi?
Okay. So let's pretend I have an unlimited budget. What would you recommend then?
clubbedtodeath
- Expert Member
You could try looking into G-Force's Virtual String Machine (VSM). Sound on Sound speak very highly of it:
https://www.soundonsound.com/reviews/gf ... ng-machine
Disclaimer: I have a Waldorf Streichfett which I like very much, so I don't have the VSM.
Thanks. VSM sounds quite good. I might get it on Black Friday when it's cheaper. Also, from the demos I've been hearing, Arturia's take on the Solina sounds pretty nice as well. Has anybody tried that Arturia plugin?
- madtheory
- Real name:Tomas Mulcahy
I think VSM is great, it's got everything. I've seen people complain that it doesn't have the synchronous clocking that a real stringer would have, but that's dumb because most of the time you're putting it through the chorus as well, which is not synchronous. Stringers are the one thing that it's VERY easy to emulate.
If you have Kontakt, these guys have excellent stringers for cheap:
https://www.rhythmicrobot.com/keyboard-vault
The Korg Lambda is perfection itself.
The Arturia Solina V is great too. Possibly more flexible than samples, but it doesn't quite do the Crumar, Korg or Roland stringers.
NI Reaktor has a perfect Jarre Eminent thru a slowed down Small Stone Phaser, so there's that.
Have you checked out any of the freeware ones? I've used String Concerto II by G-Storm.
Classic lo-fi, retro, vintage-style patch banks for:
- Broadwave
- Gear:Kronos 2-88, Fantom 6, Novation Summit, ASM Hydrasynth, Modal Cobalt8, Behringer Odyssey, Behringer Poly D, BroadWAVE ARP 2600EX.
TBH, I wouldn't bother with sample based VSTs - they offer a great deal, but never seem to sound quite authentic.
If you can push yourself to €99, I would recommend The Crumar Performer VST which I can vouch is a PERFECT rendition of the original Performer which I had for many, many years.
https://www.crumar.it/?a=showproduct&b=41
- Tchammosaur
- Junior Member
- Real name:Alex
- Gear:Right now: all in the box, except Volca Modular.
- Band:Alaska
This is free until the end of the month and seems high quality, albeit not aiming to replicate 70s string machines exactly: https://www.arturia.com/products/softwa ... o/overview
The "Syntronik String Box" expansion for IK Multimedia's Sampletank sounds really good and faithful to the original!
I have a new favorite. The freeware plugin called Oxid by Fullbucket does a 10/10 spot-on old school string synth sound.
