Modular softsynth
- ex_action_figure
Are there any modular softsynths like the Nord modular but that don’t need their own hardware?
Something close to nord modular though were you can pick your own modules and everything I’ve used moog modular and it’s allright but I want something more modern.
Any ideas?
Any ideas?
- Analog Freak
You can actually run the G2 Modular software without the hardware. People that own the G2 say there is no audible difference. I put up a post on it here: http://matrixsynth.blogspot.com/2006/01 ... ar-g2.html
The only limitations are:
* Polyphony is limited to one voice while the hardware has a maximum of 32 voices per sound.
* The demo can only play one sound at the time while the hardware is 4 part multitimbral.
* A couple of modules are disabled.
* The demo does not support audio in and MIDI out.
- Analog Freak
Applied Acoustics Tassman is really good. Easier to use than Reactor.
Native Instruments Reactor. One of the most flexible but very hard to build your own.
Arturia Moog Modular V. A big old Moog system. Probably the easiest to use.
Akai EWI4000s, Akai EWI1000, Oberheim Xpander, Waldorf XT, Alesis Micron, Alesis QS7, Kawai K5, Sequential T8, Prophet 5, Pro 1, ESQ-M, TX7, Roland D70, Yamaha VL-7, Yamaha DX9, Applied Acoustics, Arturia
Reaktor....f**k ENDLESS. Who needs to roll your own when there's HUNDREDS of free ensembles out there in the NI library. Absynth is unsneezeable also. Version 4 is just about out.
Tassman is unique in design...very old school, very oriented towards acoustic emulation/physical modelling/FM. VERY easy to use.
Crystal is FREEWARE, and insanely flexibile.
A couple of new tri-oscillator semi-modulars: Surge and MX4. Both sound phenomenal.
Zebra2....spooky-a*s UI & easily reconfigurable. COME ON, Urs!!!!!!
- ex_action_figure
Thanks guys tassman seems really cool I’m going to check that out max/msp looks nuts I'm sure it's awesome but I want something a little more simple
I've been using the clavia demo but I never got to into it because it's just a demo but I didn't realize how few limitations it had until now maybe I’ll dig a little deeper
- ex_action_figure
- THM
- Gear:ARP 2600
Elka Synthex
EML Polybox
EMS SynthiAKS
mTron
MOOG Mini- & Memorymoog
Oberheim SEM
Roland Jupiter-8/...
Yamaha CS80
DotCom
>see MySpace - Band:THM
DotCom Modular * ARP 2600 * Elka Synthex * EML PolyBox * EMS Synthi AKS * MOOG Minimoog Model D, Memorymoog * Kurzweil PC88 * Oberheim SEM * Roland Jupiter-8, JP-8080, Juno-60, TR808, TB303, MKS50, RE301, SDE330, SRV330 * Yamaha CS0 * see THM on MySpace
Synthedit... It can be hard to get synthedit to sound great (it'll sound good but it's tough to get it to sound great) but it is a lot of fun and very easy to use. I think once you use synthedit it spoils you against evrything else. It has the best interface going. It's just click and connect. There are a lot of third party modules so you can download a few and try them out.ex_action_figure wrote:Anyone know of any that are like doepfer or analog systems
Where you could pick from different modules and then patch away?
Max/Msp sounds a lot better IMO. I tried some comparable patches in both like FM and Max/Msp sounds a lot better. The learning curve is a lot steeper. For me it's not as much fun to use. You seem to be constantly dealing with numbers and converting one set of numbers into another. That bit's a piss off for me. Also Max/Msp is more geared toward manipulation of audio. For example it has no Doepfer style oscillators you have to make them from ground up everytime...
Reaktor and Generator before it never really did it for me. It was expensive and I never really though it sounded that great.
I'd try out Synthedit. It's shareware so its not costing you anything and they have a fantastic user community. Very friendly and helpful..
- Bitexion
- Gear:Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Waldorf Blofeld - Location:Drammen, Norway
Moog Modular V, while amazing, is still a fixed system. I think he wants to be able to place modules himself. Not that you'd need alot of more modules in that system, but still..you need to learn how to work it to get much out of it.
There is a great free modular synth that let you place modules yourself.
http://www.karmafx.dk/
The modular is on the lower part of the page. Completely free, and sounds wonderful. You place the modules you want, then draw connections between then with the mouse (or right click and select destination). The cool thing is you get an oscilloscope visual of the signal on every module. So you can see the sawtooth wave fluttering about in realtime when you play it. And the virtual cables are behind the modules, not in front like the MMV. So nothing gets in the way of tweaking.
KarmaFX was voted as the best free modular system in Computer Music magazine not long ago. They set it next to Reaktor, a monster package, and gave it very high marks compared to the big commercial one. He designs the modules from scratch, so it doesn't sound like "just another synthedit frontend"
- krushing
- Real name:Petteri
- Gear:Doepfer Dark Energy, Nord Lead 3R, Waldorf MicroQ, Acidlab Bassline 3, Roland TR-606
- Band:Salaneuvosto
I'll second Zebra 2. It's amazing. VAZ Modular is another good one, and finally KarmaFX Synth is pretty similar and best of all - FREE.
