Hi all, I have been using soft synths for a while now but they have all been standalone programs (Pro-53, Minimoog V). Just recently I bought Sonic Projects OP-X which only comes as a plug-in so I have had to venture into the world of VST.
I am using VSThost and everything is working fine except for the MIDI. The MIDI functions but I get annoying clicks in the sound if I use 5 or 6 voice polyphony on the OP-X or in unison mode. I made a demo to demonstrate this where I am attempting to recreate a couple of classic Oberheim sounds:
http://azuv.com/clickdemo.mp3
I'm pretty sure it's the MIDI signal causing this rather than a signal overload of some sort. The clicks occur whenever a MIDI signal is sent, whether pressing the keys down bringing them back up. I am using an M-Audio 1296 on a Pentium 4 machine running Windows XP. My MIDI source is an old Technics keyboard.
I have two theories so far. First is that my keyboard is very old (late 1980s) and only sends in omni mode. I wonder if that may cause a problem.
My second theory is that there may be a problem between VSThost and OP-X. I would like to try a different VST host to see if that makes a difference. Are there any other free ones available out there?
Any other ideas?
MIDI problems with VST
buffer size
I listened to the example and it sounds more like a buffer/latency issue. If the latency or buffering is set too low for your sound card to handle you can get clicking or distortion depending the softsynth.
Deceptive Intentons.... Making today worse so tomorrow seems better...
Emax HD - CS2X - Triton LE - EMU PK6 Expanded - Enonic ZR-76 - Micron - K-Station - Protools LE - EIIIxp - EIIIxs - ESI4000
