jupiter 8v static im hearing
silversurfer1919
Post by silversurfer1919 » Sat Jun 02, 2007 8:35 am
ok is this because that im still running a demo in my sequencer ((ableton live)) that im hearing static?? Has to be because my computer is pretty powerful imac core duo 2.16 when i play the jupiter i hear the sound of the patch and aslo staticy sound with the patch was this because im still running the demo because i installed the jupter8v and everything?
ill try to mess around with my puter some more i didnt install the sychrsoft key didnt think i had to because i downlo9aded the latest version and installed it when i bought the prophet 5v
anyways with all of that i messed with the jupiter 8v and its worth every penny its turning out to be my fav vstsynth and its so easy to make weird sounds with the sequencer and the distortion effect makes the sound growl! also the delay is top notch in my opinion.... anyways peace
silversurfer1919
Post by silversurfer1919 » Sat Jun 02, 2007 8:52 am
ok now in ableton live i hear static but in logic 7 it plays cyrstal clear is anyone who uses live getting the same problems??
chamomileshark
Post by chamomileshark » Sat Jun 02, 2007 8:03 pm
Do you mean a burst of noise sometimes? If so and it's the demo it's because it is the demo version. Otherwise possibly something is overloading somewhere or you are running out of RAM..I sometimes got the same thing with the full version of the Arturia's Modular.
mr_m0nks
Post by mr_m0nks » Sat Jun 02, 2007 8:32 pm
if you have had the demo version and then bought the full version you will still need to register the full version with syncsoft i think
Alesis Ion, Korg Poly800II, Akai S1000, CommodoreC64, Nintendo Gameboy and various software Synths.
http://www.myspace.com/thesilentjihad
Listening to far to much Yazoo
silversurfer1919
Post by silversurfer1919 » Sat Jun 02, 2007 10:00 pm
so why is the jupiterr 8 playing fine in logic 7 and not ableton?? I was able to launch the standalone with no problems....are you using live and are not having problems with jupiter 8v? plays krstal clear?
Shleed
Real name: Ashley Dolan
Gear: Doepfer A100
MFB Synth II
Korg MS20 Mini
Ensoniq EPS-16+
TT303
TX81Z
Band: Shledge
Post by Shleed » Sat Jun 02, 2007 10:55 pm
Just buy the full version.... then all that "static" nonsense will go away.
Sweetnothing
Post by Sweetnothing » Sat Jun 02, 2007 11:30 pm
Are any audio inputs open? try to mute those tracks and see if the noise comes from there, as live always loads one audio track on the default template
