How do I register DirectX plugins with Windows so that they are recognized by my Sequencer programs? I used to use the DirectX Manager from AnalogX.com, but it doesn't work in Vista.
With DirectX Manager I could register or remove from Windows registration any DirectX plugins bu just dragging them onto the manager program.
Is there something else I can use that does the same thing?
How do I register DirectX plugins?
MrHope
- No Longer Registered
How to Register DirectX plugins in Windows Vista
OK, I figured out the solution:
Follow these steps to register (DirectX) DLLs (or OCX's):
1. On the Taskbar, select Start > Run.
2. In the Open field, type regsvr32 "<path>\NameOfFile.extension", where <path> is the directory where the file is located on your computer and NameOfFile.extension is the name of the file. For example: regsvr32 "C:\Windows\System32\ReverbDirectX.dll"
3. Press Enter.
To unregister/remove a DirectX DLL, type regsvr32 /u "<path>\NameOfFile.extension"
3. Press Enter.
