hello all. im interested in learning how to compose and arrange string ensembles. what software would be good for this? ie. where i can write information as sheet music, opposed to just in a piano roll.
thanks. dd
software for classical compositions
ned-ryarson
- Stab Frenzy
ned-ryarson
ned-ryarson
- Stab Frenzy
- nathanscribe
- VSE Review Contributor
My better half uses Sibelius all the time and swears by it. Good for writing direct to score, simple interface, good layout, includes Kontakt player so you can add libraries easily - but it's not cheap. If you're serious about this way of working, it's hard to beat, but it's not the best choice if you want to dabble. Cubase has a score edit mode, so you could pick up the basic version to try it out. I never found it that user-friendly though.
Neither of these programs will teach you about the compositional aspects, though I'm sure there are guides out there for studying orchestral writing techniques.
- CS_TBL
- Gear: All "In-The-Box"
Mainly FM8 - Location: NL
If you're not scared away by a bit o' low-level programming, how about lilypond? (www.lilypond.org)
It's supposedly the best quality printed score on this planet.
FM8 vids
FM8 vids
- krushing
- Real name: Petteri
- Gear: Doepfer Dark Energy, Nord Lead 3R, Waldorf MicroQ, Acidlab Bassline 3, Roland TR-606
- Band: Salaneuvosto
Here's a good primer on orchestration:
Garritan's Principles of Orchestration
