Native Instruments Maschine
JSRockit
Post by JSRockit » Tue Jan 27, 2009 4:48 pm
As a long time MPC user and also a long time Ableton Live user... I must admit that I have pre-ordered the Maschine. After watching all the videos... it seems like it'll be, if it works as NI says it does, a good alternative to the MPC. Anyone else into the NI Maschine?
aXL
Gear: Moog LP Stage II, Ensoniq ESQ-1, Nord Electro 3, Roland JP-8080, Akai SynthStation 49, numerous softies...
Band: Nemesis Kane
Re: Native Instruments Maschine
Post by aXL » Tue Jan 27, 2009 5:14 pm
I will definitely consider it later on, if the controller is as hands-on as the preview says and the on-board sequencer is that easy to use and set up. When (or indeed if) I ever have to go live, Maschine would be seriously cool to have with a good laptop.
But for now I run Battery 3, and that works for me. Though I must admit I am drooling heavily when thinking about how Maschine is laid out, so if it can load Battery series kits, I'm sold.
Sir Nose wrote:It's like sex with or without a condom. You know which choice is gonna feel better, but it's not always a wise choice.
Disciples of the new wave, portaits in the sand...
Hugo76
Post by Hugo76 » Tue Jan 27, 2009 11:33 pm
It looks very cool indeed, but it would have to be workable as a standalone unit for me to be buying it. Anyone know more about this?
bluedad
Gear: Yamaha Motif ES rack/DX7//TG77/SY77/AN1X/MM08 MicrowaveXT/ Korg DW8000/M3r/ Ensoniq ESQ-1 /Mirage Rack/ Nord Micro DSI Mopho Roland Juno 106/D550
Band: Split Second
Post by bluedad » Wed Jan 28, 2009 12:17 am
Hugo76 wrote:It looks very cool indeed, but it would have to be workable as a standalone unit for me to be buying it. Anyone know more about this?
if you mean just the controller without a computer, then the answer is no.
also it does not load battery kits..maybe later.
Hugo76
Post by Hugo76 » Wed Jan 28, 2009 4:18 pm
bluedad wrote:if you mean just the controller without a computer, then the answer is no.
Too bad... It's not for me then. Still a cool bit of kit, though! :D
Gregor Samsa
Gear: Too much (not enough).
Post by Gregor Samsa » Thu Jan 29, 2009 2:28 am
If it doesn't load battery kits, then what does it load?
carbon111
Band: Carbon111
Post by carbon111 » Thu Jan 29, 2009 2:47 am
JSRockit wrote:As a long time MPC user and also a long time Ableton Live user... I must admit that I have pre-ordered the Maschine. After watching all the videos... it seems like it'll be, if it works as NI says it does, a good alternative to the MPC. Anyone else into the NI Maschine?
I'm probably going to pick up a Mashine. :)
Been looking for a "grown up drum machine" for a while and I think this will fit my particular needs nicely...
Best Regards, James
My New album "Persephone":
diezdiazgiant
Band: jizzflap f**k
Post by diezdiazgiant » Thu Jan 29, 2009 6:33 am
Apc40 has more of my attention, thoguh I gotta say it does look kick a*s
blunted daydreaming
MitchK1989
Post by MitchK1989 » Thu Jan 29, 2009 11:32 am
I might be interested once the plug in has midi out. Right now you can use the controller as a pad controller for other software, but you can't use the sequencer for anything but the maschine software itself yet.
JSRockit
Post by JSRockit » Tue Feb 03, 2009 2:04 am
Ah, so you want it to be true MPC clone huh Mitch?
MitchK1989
Post by MitchK1989 » Thu Feb 05, 2009 3:08 am
JSRockit wrote:Ah, so you want it to be true MPC clone huh Mitch?
I just would find it a lot more interesting if I could compose using its sequencer without having to use samples for everything, especially since I'm not terribly fond of using samples for melodic parts. Being able to sequence µTonic and Surge with it would be awesome.
JSRockit
Post by JSRockit » Fri Feb 27, 2009 4:30 pm
You can use it to control plugins...
http://www.native-instruments.com/newre ... GUI_01.png
RobotHeroes
Gear: a toothed wheel that engages another toothed mechanism in order to change the speed or direction of transmitted motion
Post by RobotHeroes » Sat Feb 28, 2009 1:34 am
At first I thought the Maschine looked pretty good the way it worked. Then I noticed it wasn't hardware. Bummer. I would have to use my audio interface to sample which I can already do without it.
I don't remember the exact buzzwords they were using but I think they were pushing speed. They can switch sounds as fast as they want, or even telepathically, they just weren't convincing me. If I am going to throw down for a sampler I want it to be able to sample on it own. I don't like it when a piece of gear requires something else to function, like monome's.
I like how it works though. I think I read that it can't be used to sequence other gear though. Is that true? That would suck if you liked the interface. And latency! One thing I hate about sampling/recording with software is latency and having to adjust things to line up right. :x Then again either way you have to work on your samples when doing songs but live? I could hear it sounding terrible in my head. Samples all off and stuff.
diezdiazgiant wrote:Apc40 has more of my attention
Ditto. As I slowly get into Live for Dj/Performance the APC40 has the goods. Hopefully it works good on release and no nightmare stories.
"*Automatic Gainsay, you ignorant slut." - Primal Drive
"thanks guys. RobotHeroes, your avatar is the single most important thing on this website. ever. it reminds me that the world actually can be a good place." - rjd2
:happy3:
JSRockit
Post by JSRockit » Sat Feb 28, 2009 1:49 pm
Well, mine finally arrived... I'll let you guys know if it sucks or not... you know that.
MitchK1989
Post by MitchK1989 » Sat Feb 28, 2009 2:29 pm
JSRockit, it does let you use the maschine as a midi controller, but the sequencer itself is part of the plugin. So although you can use Maschine as a pad controller for other software, you can't use it to arrange entire songs using its sequencer unless you use maschine sample based sounds only.
