Ableton controller?!
UnbalancedKarma
Real name:Fabio
Gear:Ensoniq: SD-1/32
Kawai: K1m, K3, K4r, K5
Oberheim: DPX-1, OB-12
Quasimidi: Raven Max, Sirius
Siel: Mono
Band:Unbalanced Karma
Post by UnbalancedKarma » Sun Aug 17, 2014 5:55 pm
hi!
I'm new to Ableton, anyway I'm considering a controller, 'cause I think it will be very useful for programming, recording sequences, mastering etc.
I'd like to use Ableton as a sketchpad for working on new ideas too, so it has to have a keyboard, some knobs, and be very portable (like I may use it with a laptop on a park, or a train, or something)...
so...
http://www.reloop.com/reloop-keypad
or
http://akaipro.com/product/apc-key-25
...or!?
balancing Karma with Music.
UnbalancedKarma
Real name:Fabio
Siel: Mono
Re: Ableton controller?!
Post by UnbalancedKarma » Mon Aug 18, 2014 10:27 am
anyone?
p.s. I'm not sure this is the right section for posting this... :oops:
pflosi
Gear:more than 150 characters...
Post by pflosi » Mon Aug 18, 2014 11:22 am
Have you considered breaking things out, e.g. Push + some simple midikeyboard...? I think I'd prefer that to those "all in one" Akai etc. midikeyboards. But YMMV - what do you want to do with it?
UnbalancedKarma
Real name:Fabio
Siel: Mono
Post by UnbalancedKarma » Mon Aug 18, 2014 6:02 pm
hi!
yes I think I owe you a more in-depth explanation!
I'm used to work with hw sequencers (Quasimidi Raven and Sirius, Ensoniq SD-1) and synths (see my signature)...
I mainly used Cubase for recording, anyway I really hate it, plus I think another DAW will be much more inspiring also when composing (think about the red box Vs a plain pattern-based sequencer)...
Moreover, I'd like to play live too (I'm a one man band), using a laptop with a DAW running my backing tracks (I'll play guitar + voice live)...
Finally, I'd like to be able to compose also when I'm not in my studio, so my laptop, Ableton and a very portable controller (useful also when mixing and recording track automations etc.) could do the trick!
So I think Ableton will fit the bill for all my goals! for these reasons, I'd like a similar controller...
I think the AKAI APC key 25 is the best solution...
it does not need power supply; it connects directly via usb, so it does not occupy another midi port on my midi patchbay, and can be used also on pc that have no midi interface (like an home pc, or a laptop); it's a dedicated controller; it's very cheap, it's very portable, and has a 5x8 launch grid!
it only has 8 assignable knobs and no pads, but you can use the keyboard to enter drum notes anyway...
and you can use some of the clip launch pads to trigger other midi events...
the Keypad has no red box and it's way less flexible, I think, even if it has a lot more dedicated knobs/faders...
(p.s. sorry for my english, it's not my first language :oops: )
pflosi
Post by pflosi » Mon Aug 18, 2014 10:45 pm
Yeah sounds like you're convinced already - you can always add something else later :thumbright:
Good luck!
UnbalancedKarma
Real name:Fabio
Siel: Mono
Post by UnbalancedKarma » Tue Aug 19, 2014 10:27 am
actually, not 100% true, since there are a lot of similar compact controllers out there (Novation Launchkey and a lot more), anyway... :P
pflosi
Post by pflosi » Tue Aug 19, 2014 10:42 am
Well, someone else has to chime in to give you a proper review / comparison of those... Don't have too much experience with them, I somehow don't like midi controllers that much after all...
UnbalancedKarma
Real name:Fabio
Siel: Mono
Post by UnbalancedKarma » Tue Aug 19, 2014 12:02 pm
pflosi wrote:Well, someone else has to chime in to give you a proper review / comparison of those... Don't have too much experience with them, I somehow don't like midi controllers that much after all...
yep, I know your feeling! my only dedicated midi controller right now it's a Kenton Control Freak!
having an OB-12, I know it is an h**l of a controller too, correctly mapped to VSTi (one of the most knobs/sliders populated synths ever)...
UnbalancedKarma
Real name:Fabio
Siel: Mono
Post by UnbalancedKarma » Thu Feb 19, 2015 12:39 pm
ok!
so I got myself an APC Key 25 AND an LPD8.
:D
loungedumore
Gear:iMac | iPad 2| iPad Air
Beatstep Pro | Mpx8
Volca bass, Keys ,beats
Monotribe | MS20 | SQ1
Minibrute | Midi4+
Graphite 49 | EIE
Band:Death By Media
Post by loungedumore » Thu Feb 19, 2015 3:24 pm
If you got max 4 live as well you could try the MPK MAX EDITOR http://www.maxforlive.com/library/device/2084/mpkmax ( for mpk mini , but the lpd8 should work ? )
I use a few different sequencer patches for my launch pad and for me it makes it feel like hardware were I'd want it to be . The roll your own approach once comfortable enough M4l makes almost any midi controller more useful .
Mr Knesh
Real name:Roland
Gear:DP/4+ because in order to dive in deep, you have to DP.
Post by Mr Knesh » Fri Feb 20, 2015 7:56 am
I have been using a Novation Launchpad and recently added a Novation Launch Control to my mobile production. I honestly don't need a keyboard for composing music on the go.
UnbalancedKarma
Real name:Fabio
Siel: Mono
Post by UnbalancedKarma » Sat Mar 21, 2015 1:29 pm
loungedumore wrote:If you got max 4 live as well you could try the MPK MAX EDITOR http://www.maxforlive.com/library/device/2084/mpkmax ( for mpk mini , but the lpd8 should work ? )
thanks for the advice! I will take a good look at it! I hope there were more of these!
let's keep this topic alive ;)
erikesimmons
Post by erikesimmons » Tue Apr 14, 2015 9:51 am
Before starting you may need to install driver software that came with your controller, so check the instructions that came with your hardware.
First, plug the square side of a USB cable into the controller, and the wide side into a USB port on your computer.
Some controllers get the power they need just by connecting them to the computer’s USB port. But if your controller doesn’t, you’ll need to connect it to a power source and then turn it on.
Now launch Live. Go to Live’s Preferences by hitting [Control + comma] on a PC, or [Command + comma] on a Mac. Click on the MIDI/Sync tab.
If your controller is set up properly, you should see one or more Input and Output entries for it in the MIDI Ports section. Now turn on the Track switch for your controller's input port.
Your controller should now be set up to play instruments in Live. We can check this by playing the controller and seeing the yellow flashing square in the upper-right hand corner.
Real name:Unpronounceable
Gear:Ensoniq SD-1/32,SQR,VFX,ESQm
Band:Eridani V
Post by Ashe37 » Tue Apr 14, 2015 11:15 am
Actually, some controllers, especially Ableton controllers, don't have drivers. I have an Akai APC 20, and it has no drivers. Aleton just recognized it once Windows installs the USB driver for it.
