I'm looking for an old sample drum machine but don't know how to find one, any good recommendations? I already know about the well known ones such as the sp12 and ensoniq stuff, but are there any other machines that aren't that well known.
Really the only functions I need is to be able to sample and of course I want a gritty sound.
8 / 12 bit samplers?
- meatballfulton
- Moderator
- Gear:Logic Pro X
Ableton Live
Nektar Panorama P6
Launchpad X
MOTU M2 interface
Re: 8 / 12 bit samplers?
Casio RZ-1, Zoom ST-224, Korg DDD-1, Korg DDD-5
Korg DDD-5 didn't sample, and the DDD-1 did, but only with the optional sample board...
There's also the RSF-SD140, the SP12/SP1200, Linn 9000, SCI Studio 440 that spring to mind...
Then of course there was the EPROM machines where you could burn samples onto your own chips with eg Simmons EPB or Oberheim Prommer, including the Oberheim DX/DMX, LinnDrums, Sequential Tom and others...
Akai MPC60
Casio RZ-1
"There's also the RSF-SD140, the SP12/SP1200, Linn 9000, SCI Studio 440 that spring to mind..."
Those are particularly expensive, and most are quite rare. Casio RZ-1 is the only currently affordable 8/12-bit drum oriented (not a rack or keyboard) sampler, but it's extremely limited.
These are 16-bit, but can get in lo-fi and gritty territory:
Zoom ST-224
Korg ES-1
Akai S20 / Remix88
Roland SP404
People have snatched all this stuff up by now, so there's not really a lot of under-the-radar/poor man's XYZ/secret-weapon options anymore. Korg ES-1 is (in my opinion) the best price-to-feature ratio for anything in this class.
Casio RZ-1
Zoom ST-224
Korg ES-1
Akai S20 / Remix88
Roland SP404
paugui
Another option worth considering, getting an 8 / 12 bit rack sampler and a proper sequencer or drum machine with good MIDI specifications for sequencing other gear.
Unless you go for something really limited, like the Casio RZ1 or Korg DDD1 (it has to have the sampling expansion fitted in), you likely will spend much more on a single drum machine, than you'd spend in this two part solution.
12 bit samplers, in particular, you have a nice amount of units available, from Akai, E-MU, Ensoniq, Roland, Yamaha and probably others...
Also, most old drum machines that had any sampling were often much more limited when it came to sampling than their rack counterparts...
I think that's true at least for the E-MU SPs, which are much more limited than the E-MU Emax I...
On most excellent samplers, you can drop the bit rate of a sample; even the sp202 has a lofi option that achieves this.
