Sampler with Trigger inputs????
Forefatherss
Basically I am looking for a sampler that has some trigger inputs. I have no idea if this even exist!! Basically I want to sample my own loops from records and my keyboards onto a sampler then play them on separate drum pads. Which brings up my next thought which is could a midi controller pad like an Alesis Control Pad or Roland SPD that has midi be plugged into a sampler with midi and be controlled that way?? I am guessing it can but I would want to make sure I could have control over what sound is on all 8 pads and not just one sound at a time. Anyways this may sound amateur as I am a drummer trying to incorporate samples into my set but any help would be appreciated. Thanks!
- piRoN
- Gear: A fair bit.
The Akai S900 had 8 trigger inputs as an option, with velocity sensing and all that. I've got a drummer mate with one in his rig and it seems to work pretty well.
As to your second question; yep, that's easy. Drum signals over MIDI are just normal MIDI notes, so you just need to set up the keyboard range for each sample to whatever key each pad is sending.
gcoudert
- Expert Member
- Real name: Gilles
- Gear: Roland Fantom X7 with Ultimate Keys expansion, Yamaha TX802, Roland JP-8080, Tascam DP-24SD.
According to the Akai S2800i manual, an audio/MIDI drum trigger interface called ME35T (it's a single-rack unit) can be used in conjunction with the sampler, and probably with any other S3000-series machine.
Have a look here: http://matrixsynth.blogspot.com/2006/12 ... igger.html
Gilles
Gilles
GC
- tyrannosaurus mark
- Analog Freak
