Emu E6400 Ultra, built in sequencer any good?
I have been doing a lot of research to try and find the right rack sampler for my needs and the Emu seems to fit the bill nicely. I was planning to buy an MPC 1000 for drum sampling and also use it to sequence the Emu. However I believe the Emu has it's own 48 track sequencer built in and I was wondering whether or not the MPC would be redundant in my set up if I get the Emu?
No, it wouldn't be redundant. I don't use the sequencer on any of my E-mus because it is not nearly as sophisticated as the MPC sequencer and likewise the MPC sampler is not as sophisticated as an E-mu sampler.
There is very little overlap between them. You may find that you like the E-mu sequencer, but it is sort of limited and I thought it was uncomfortable to work with. I'm not saying you won't like it, but it is not really like an MPC sequencer.
gcoudert
- Expert Member
- Real name: Gilles
- Gear: Roland Fantom X7 with Ultimate Keys expansion, Yamaha TX802, Roland JP-8080, Tascam DP-24SD.
If it's like the E4K's sequencer (and it must be), I'll second that. And sequences aren't editable.plus321 wrote:You may find that you like the E-mu sequencer, but it is sort of limited.
I record my sequences in Cubase, save them as MIDI files and play them from the E-mu. Incidentally, the beauty of the E-mu's sequencer is that it outputs MIDI sequences through its MIDI Out, unlike Akai's S2000 and S2800i, which play MIDI files but only using their internal sounds.
Gilles
GC
Sounds good, I read a thread on emusforacid from about 2003 where a guy said that he liked using the Emu sequencer but he only used 8 loops or so at a time to do a minimal hip hop style of music. From what you are saying if I go for the Emu and the MPC I would have kind of the best of both worlds!plus321 wrote:No, it wouldn't be redundant. I don't use the sequencer on any of my E-mus because it is not nearly as sophisticated as the MPC sequencer and likewise the MPC sampler is not as sophisticated as an E-mu sampler.
Thanks for the insight.
Thanks for the info, I had no idea that the sequences from the Emu were not editable and it is now becoming obvious to me that the MPC + Emu combo is definately the way to go, especially for live use!gcoudert wrote:If it's like the E4K's sequencer (and it must be), I'll second that. And sequences aren't editable.plus321 wrote:You may find that you like the E-mu sequencer, but it is sort of limited.
Gilles
