Korg ESX-1 with Roland TR-x0x's
ramos
Post by ramos » Thu May 15, 2008 2:24 pm
Hi there,
I'm thinking about getting one of these, but need to know a couple things first. I thought about the MPC, but I prefer the randomness/structure of step sequencing.
I want to use my own samples in conjunction with my TR drum machines, just some drum samples, sound effects, pitched vocals etc.
I've never used a sampler before, but I imagine the ESX can be used just like an 808, and all i have to do is sequence my samples, and sync it up?
Obviously I need a dinsync to midi convertor, which do you guys recommend? I'm thinking about the Kenton Pro 2000 or the Mark II from http://www.innerclocksystems.com/ thoughts?
Excuse the newb questions, Im just having trouble working out in my head how I'm going to integrate everything.
All I want to do is sequence the ESX, so it can play the samples in time with a master clock, I'll also be using the other equipment in my sig, so I'll need a convertor to accomodate the other dinsync gear. I can trigger the sh-101 with the 707, so thats no problem.
How hard would it be to incorporate the esx, 808 etc, into a live act?
Thanks!
Sh-101, tb-303, Juno-6, Jx-3p, TR-808, TR-707, TR-727,Oberheim DMX - Tascam m-312b + ghetto effects
shaft9000
Real name: Dave
Gear: Whips chains and a contract.
Post by shaft9000 » Thu May 15, 2008 6:49 pm
w/ a dinsync->MIDI converter you should be set.
You might want to add a MIDI thru box to avoid daisy-chaining MIDI cables, reducing MIDI-sync lag.
the ESX can act as MIDI masterclock or it can sync as a slave.
.svc350.memotron
sineSurfer
Real name: Freddy
Gear: X50, MS2000, ESX1, EMX1, BassStation, Proteus/1, Electric drumkit +DM5, x0xb0x 393, theremin, mbSid stereo, MB6582, MB808, MBSEQ, Fatman.
Band: Hakken
Re: Korg ESX-1 with Roland TR-x0x's
Post by sineSurfer » Sat May 17, 2008 7:50 pm
ramos wrote: I imagine the ESX can be used just like an 808
Thanks!
You'll feel right at home on the ESX with the TR style sequencing, it's even easier than the 808.
Both the kenton and the markII look like a good choices, or you can get a midi retroft kit for the 808:
http://www.synhouse.com/midijackdinsync.html
http://www.chd-el.cz/index.php?id=358&lngid=en
Riding the wave
ramos
Post by ramos » Thu May 29, 2008 2:50 pm
thanks for the help guys
