What make the bits?
Userfriend
What make the bits?
Hi. I wonder if it´s the AD and DA converters that alone settle how many bits a sampler has.
Re: What make the bits?
It is possible to feed 16 bit samples into a 24 bit DAC without loosing information. However, feeding 24 bit samples into a 16 bit DAC would loose information. My guess though, the samples would be recorded at the bit level of the hardware. Also, it would be safe to say that the playback would be the same. It wouldn't make much sense feeding a lower bit rate sample into a higher bit DAC. You wouldn't gain anything.
Analog: Mono/Poly, Prophet '08, Juno 106
Digital: Kurzweil SP88, Yamaha DX11, Kawai K4, MS2K, AN1x
Modules: Triton (loaded), Motif ES, MS2KR, E-Mu Proteus 2K, TR626 DM, Roland U220
New Addition: Fender Rhodes 73 Mark I
So much gear... So little time!!!
- Synthaholic
- Expert Member
It's primarily the design of the A/D converter and the word size of the sample memory that determines the bit size of the sampler.
Some A/D converters oversample; that is, they sample more bits than are needed, then the result is rounded off. So, a 16 bit sampler may use a 18-20 bit A/D and D/A. The bits are rounded down to 16-bits when recording and upsampled back to the D/A's bit depth on playback. This results in better accuracy and less noise on the old "parallel" type D/A converters. You might remember CD players in the late 80s advertising "4X oversampling", that's basically just converting 16-bit samples to 18-bits, quadrupling the sample rate, to improve quality by moving quantization noise into higher frequencies where they're easier to filter.
- Stab Frenzy
Actually, it's the sampler's design team that decide how many bits the sampler has. The AD and DA convertors determine the upper limit of the input/output bit depth, the sample engine determines where it'll sit within those parameters, but the design team works out how it all fits together.
A sampler could use a 24 bit engine internally and then dither down to 16 bits on the output and go through a 16 bit DA convertor. Or it could run everything at 24 bits but have the ability to import 8 bit samples and play them back with all their crunchiness. It really depends on what the people who designed the sampler decided what they'd do and how they'd implement it.
As high as possible. Everything under 96 is substandard and unacceptable in the modern world.
Listening to 16 bit samples is like having one's ears grated by the not italian people who work at olive garden and consider themselves qualified to dump parmesean cheese on your overly large salad if they were to decide to apply their skills to the torture of electronic musicians instead of relatively expensive dairy products. A thoroughly unpleasant experience by any means.
Though it would be economically beneficial for me to sit back watch your attempts to make music fail utterly as a result of the terrible decision you would be making by buying a device of such inferior quality, I will be nice you and offer my advice as you call yourself both "user" and "friend".
http://en.wikipedia.org/wiki/Sample_rate
http://en.wikipedia.org/wiki/Bit_rate
PowerMac G4 dual, DSI MoPho, E-MU XL-7, Korg ES-1mkii, Korg EA-1, Novation Nova, Kawai K4, Casio vz10m, Casio ht700, Yamaha PSS-480
(5 good trader references and counting)
Userfriend
Thanks for answers.
But Sacredcow, it seems that you´re trying to say something else than this subject is about. There´s other threads for your subject. Your attitude did´nt provide anything positive.
- HideawayStudio
- Real name: Dani Wilson
- Band: Shortwave
sacredcow wrote:As high as possible. Everything under 96 is substandard and unacceptable in the modern world.
Errr... say that again?.... you either have the ears of a well trained bat or some overpaid rep from SSL has hoodwinked you - you're not.... heaven forbid... an audiophile?? Personally I prefer washing all my recordings through a back to back 8 bit converter running at 128KHz... far more precious! Fairlight eat your heart out
H.I.D.E.A.W.A.Y S.T.U.D.I.O
http://www.hideawaystudio.net
The Home of Novachord #346
http://www.novachord.co.uk
- HideawayStudio
- Band: Shortwave
Hmmm.... PPG Wave.... I'm in heaven.... now there is a good example of 8 bit sampling at it's best into analog filters - simple really, one makes the lovely music related harmonics and one removes some of them againwaveterm wrote:Huh ?
WT
When will these modern synth designers get it clear in there minds that better DAC specs do not equal more musical results.... yes 24 bits+ have their place in recording orchestral instruments but synths?? Seriously - sample a synth pad on a 12 bit EMAX and then sample the same pad on an EIV or your latest soft sampler - then tell me which one sounds more alive...
