Need help with ESI-32 loop point / crossfade
Posted: Thu Aug 06, 2009 10:22 pm
by D-Collector
Ok here's the deal, I have sampled some of my favourite patches from my JX-8P to my pc and made wav files with loop points and crossfade in sound forge 4 (old but good). I read that the ESi can read wav files with sound forge 4x loop point, and it does. But unfortunately it won't read the nice crossfade I made in SF. I have tried them also with the sampler in orion 7 which reads all the xfade and loop info in the file. They are nice and smooth, and sound very good. I don't have much experience with sample editing on the ESi because most of the time I use the EIIIX library on scsi cd-rom. I am simply not able to make a good crossfade in the ESi, and my best results are miles off the original nice crossfade in the wav file. :( The manual is not very helpful on the area either. Any advice here will be deeply appreciated !
Also, is there a pc program that will make finished presets in the ESi's format? The only program I have so far is ESi-Win which I use to write wav files to an ESi bank on floppy. Surely they must have used some kind of computer program when they made all the library samples?
Re: Need help with ESI-32 loop point / crossfade
Posted: Thu Aug 06, 2009 11:06 pm
by garranimal
Look for Loop Processing tools. The forward and backward arrows will help you zip to the zero-crossings. The esi-32 has 2 crossfade styles: Equal Power, and linear - both which sound good in different instances. Experiment with the crossfade time, maybe a second or two to taste, and you'll get some good results. I usually say no for 'truncate after loop?'.
Posted: Fri Aug 07, 2009 12:25 am
by D-Collector
Thanks! I will try it out.
I have also tried chickensys translator, and it reads my samples right with loop points and crossfades. And I was even able to convert it to ESi preset format. But how do I get it over to the ESi? Because it won't read DOS formatted disks. MIDI sample dump maybe?
Posted: Fri Aug 07, 2009 12:49 am
by madtheory
I used to do it via SCSI. Sound Forge supported it, not sure, can't remember...you need SCSI in your PC. You need to adjust the loop points because of a bug in the ESI...
Actually, here's an article I wrote:
http://www.soundonsound.com/sos/Dec01/a ... ede0d5b1d7
It's all in there, no need for me to remember :)
Posted: Fri Aug 07, 2009 1:19 am
by D-Collector
I have a SCSI card for pc lying around but no drivers or correct cable. #-o
You wrote that? Very nice! I have read that article many times before actually, most recently yesterday.. :D
I think I will just have to try and fail, and follow the guidelines you have given me. Or stick with the library.
Thanks, guys.
