esi 2000 and phatboy
skewbert
Gear: EA-1, ER-1, ES-1, SH-32, SixTrak, JP8080, DX 200, Nord 1, Bass Station, MG-1, ESI 2000, EF 303, KAOS Pad 2, Guitars, Bass
Band: Self Contained Unit, GeT
Post by skewbert » Thu Nov 04, 2010 11:00 pm
I recently picked up an esi-2000. I also own one of those old-school Phatboy controllers. Does anyone know it I can use the Phatboy as a parameter controller for the esi-2000?
My thought / want / desire is to midi the esi-2000 up to my Nord (as a controller) and be able to tweak Q and Res (on the esi) or whatever with the Phatboy.
Thoughts?
micahjonhughes
Re: esi 2000 and phatboy
Post by micahjonhughes » Fri Nov 05, 2010 6:04 pm
The phatboy transmits midi CC data. If the filter and resonance can be controlled by CCs, you can control them with the phatboy.
Post by madtheory » Fri Nov 05, 2010 8:02 pm
Hook it up and try it... you can set 4 MIDI ccs as mod sources on the ESI, if I remember rightly. You have to set that up for each preset though, it's not global.
