Emax questions.
Userfriend
Emax questions.
Post by Userfriend » Sat Jan 29, 2011 3:06 am
Hi, some questions about the LFOs in the Emax. Could´nt find answers in the manual.
1. Are the LFOs free running or do they retrigger for each note? or can it change between these modes?
2. Can it invert the waveform of the LFOs?
3. Can it declutch the LFOs from the mod wheel and modulate the destinations by hand, by "direct current"?
4. Can an LFO modulate more than one destination simultaneously?
chroma17
Real name: Chris
Gear: ARP Avatar, Baldwin IKE, Chroma Polaris (broken again!), Waldorf Microwave 2, Yamaha TX81Z, MKS 50, MKS 80, ESQ1, E5000
Re: Emax LFO questions.
Post by chroma17 » Wed Feb 02, 2011 6:29 pm
1. Retrigger only
2. No
3. Yes, by "direct current" or by pitch wheel, footpedal, aftertouch, or MIDI controller
4. Yes, Vibrato, Tremelo, Filter Cutoff, and Panning can all be modulated at once.
Userfriend
Post by Userfriend » Wed Feb 02, 2011 6:52 pm
THANX!
(I changed the title a bit as this topic is going more general.)
Supplemental question, about the data slider:
The manual for the Emax claims that you must retrigger a note to hear ny changes made with the data slider. Holding down a note and playing the slider will not change the sound. This applies all the changes to the sound you are trying to do this way. But the guy in this demo is obviously doing that. Am I wrong or is the manual wrong?
Userfriend
Re: Emax questions.
Post by Userfriend » Tue Feb 08, 2011 4:36 pm
Anyone who can check that, please?
alexdg
Re: Emax questions.
Post by alexdg » Tue Feb 08, 2011 10:14 pm
The only parameter in the filter menu that you can tweak in real time is the filter envelope, which is what the guy in the youtube video is doing. You can't tweak the filter cutoff in realtime, but tweaking the filter envelope level sounds similar and is an indirect way of doing it because it is controlling how much the filter envelope affects the cutoff level.
Userfriend
Re: Emax questions.
Post by Userfriend » Tue Feb 08, 2011 11:54 pm
Thanks. In other words that´s the only parameter of all that you can tweak in real time with the slider, as the manual says: "this is true when making any changes to the sound, not just while you´re in the filter function or the analog processng module. "
Juno6
Re: Emax questions.
Post by Juno6 » Fri Feb 11, 2011 12:06 am
Userfriend wrote:Anyone who can check that, please?
You can control the cutoff from the mod wheel of course, that have more sense.
