It's my first post here, so hello everyone!
I recently discovered there is something wrong with my 6 year-old Korg MS-20 Mini, specifically its Modulation Generator. I hadn't played my synthesizer in a while because various life events, but when I started getting back into it I found the knobs labeled "MG/T.ext" do nothing. I don't remember if this has always been a problem or a recent development (I struggled wrapping my head around modular synthesis even when I was playing it every day). I can still get pulsing sounds by patching, and I had the only Korg-certified technician in my area take a look at it and he said the everything is fine but the MG board. Unfortunately, the only replacement board he could find was about $600
This brings me to my question: can I get a separate LFO unit and patch it in to replace my faulty MG board and which slots should I patch into to make those "MG/T.ext" knobs work the way they should? Follow up question: could I use a Monotron Duo or Delay as an LFO?
Fix for Korg MS-20 Mini Modulation Generator
- Moderator
- Real name: Unpronounceable
Re: Fix for Korg MS-20 Mini Modulation Generator
heck for $600 you can buy a replacement...
My thoughts exactly, but since the unit is 95% perfect condition, I'd rather not throw out something if there's a reasonable work around
I was wondering if a patch was ever created? Or if you found the Board you were looking for. I also have this problem. I bought this used, had it on Layaway at a local music shop. When I put the Kork MS-20 Mini in layaway it sounded great. It had been, collecting dust on a shelf for awhile, I found the patch cables and supply. We tested it before it was put on layaway. Yesterday I went to get it and they “mysteriously” couldn’t find the power supply. I almost backed out of the layaway. The guy offered a new power supply with it. No Problem it was nice of him, but the original was there. Anyhow upon taking it out of the box the DC Jack was bigger. So I went and bought a universal one. I made sure it was a 9v supply and the polarity was correct befor plug-ins it in. Once on I get no power light and the modulation light both flash together for a split second then it seems to reset. No patches do anything and no sound from signal. I’ve looked all over the place for Codes maybe. Idk. I bought this because I was wanting to design my own Euro Rack. It’s a shame I have problems with this. I don’t want to take it back. It was 278 I know that’s a lot of money to buy something not working. Any help regarding this issue would be much appreciated. I can’t annoy my wife till it’s fixed.
Thanks for reading.
God Bless.
Thanks for reading.
God Bless.
- meatballfulton
- Moderator
- Gear: Logic Pro X
Does your power supply put out 1.7A at 9V? That's the rating of the MS20 Mini supply. If the current (amps) is too low, that might account for your problem.
Take it back to the shop. Either they find the original power supply or you should ask for a refund.
