Ensoniq SQ-R Schematic/Service Manual
rakk95
Gear: Ensoniq VFX, Ensoniq ESQ-1, Roland JV 880, Alesis QSR, Alesis Micron, Korg Polysix, Yamaha TX802
Post by rakk95 » Thu Mar 03, 2011 4:11 am
Well, I got given a broken Ensoniq SQ-R by a friend. Figured I could get it working again, but after a few weeks of flying blind, I'm officially stuck.
Problem: no audio. Digital side works (display works and the unit receives MIDI). Audio side doesn't. It keeps blowing the two 2A 250V fuzes.
Does anyone have a schematic for this model?
I want to make sure I'm replacing PS caps with the right values, etc.
Thanks -
Ry-Fi
Gear: Ion, MKS-30, MKS-50, SQ-1+ 32-voice, TX81Z
Re: Ensoniq SQ-R Schematic/Service Manual
Post by Ry-Fi » Thu Mar 03, 2011 9:26 am
I know there's one kickin around the web somewhere; I found it a few weeks ago but never saved a copy. A persistent Google search should reveal it sooner or later. Sorry I can't help more than that.
Good luck!
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Thu Mar 03, 2011 6:54 pm
www.midiworld.com/quadrasynth/qs_swlib.htm
Here is a rather good-quality PDF of the keyboard versions to get you a start.
First thing, check the minus-15-volt line (and it's regulator)
- Confucius
rakk95
Post by rakk95 » Fri Mar 04, 2011 12:34 am
rhino wrote:http://www.midiworld.com/quadrasynth/qs_swlib.htm
Thanks, man, but that's the Alesis QS, not the Ensoniq SQ...
I checked all voltages coming off the transformers, both old and new. 7VAC side read 12.30 both ways, 14VAC side read 17.86 both ways - again, both old and new transformers, so I assume I found the right replacements (even if the old ones were fine, they did look a little beat).
I assume that these are stepped down in some way on the main board to 7V and 14V, because that's where all the diodes and filter capacitors are. PS board has the choke and transformers only.
Since the digital side of the unit and the display work fine, I also have to assume that this portion of the PS circuit is working as designed.
There has GOT to be a short somewhere throwing the audio supply voltage straight to ground, because those little 2A fuzes blow instantly when the unit gets turned on. I just can't seem to find the short.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Fri Mar 04, 2011 3:38 am
Aaaaawwww, s**t !!!
Old and blind. sorry.
- Confucius
ʝɵʝɵ
Gear: Roland D-50, JD-800, U-220, XV-5080, Yamaha AN1x, CS1x, CS6R, TG77, Korg Triton Rack, Wavestate, X5DR, Kawai K4, Kurzweil K2500, Ensoniq SQ-R
Post by ʝɵʝɵ » Mon Apr 04, 2022 5:50 pm
In case anyone is still looking for it (posting here because this thread is above the archive.org link in DuckDuckGo search results), here's the service manual for the SQ 1 (Plus) and SQ-R: https://archive.org/details/sm_Service- ... _Plus_SQ-R
ʝɵʝɵ
Post by ʝɵʝɵ » Thu Sep 22, 2022 6:31 pm
Does anyone happen to have the MIDI specification document for the SQ-1/2/R? Unfortunately the full MIDI specification isn't part of the regular manual, it had to be ordered separately "back then", and now I cannot find any traces of it on the internet. This makes it difficult to work with the SysEx dump format.
