SCI Max as controller
Roosevelt1940
Hey there... I have a Sequential Circuits Max synth that I would like to use to control a Roland JP-08 boutique module, but there is apparently no MIDI out data flowing. The Max will receive MIDI from another keyboard, but simply will not drive one. I can’t find a copy of the Max Midi Manual to see if something needs to be turned on/off (the online encyclopedic copy crashes after two pages), and was hoping someone might have some words of wisdom. Thanks ever so much!
- meatballfulton
- Gear: Logic Pro X
Re: SCI Max as controller
Download the MAX MIDI Guide. Starting at page 19 it describes all the MIDI settings. Good luck!
