Yamaha SY77 error on boot
reaperc89
Post by reaperc89 » Sun May 31, 2020 9:48 pm
I've just picked up a Yamaha SY77 that I knew was broken before I got it. The synth powers on just fine, but throws up some jumbled characters and then an error on boot. I was unable to enter the testing mode in this situation.
I opened it up and looked around, the fuses were all fine, and I noticed no obvious signs of damage on either the DM1 or DM2 boards. No loose cables as far as I saw, and the battery tested out fine at 3V. I wouldn't expect this sort of issue just from a dead battery.
Anyone run into something similar to this before and have recommendations? I've attached images of the boot flow to demonstrate what I'm seeing.
Tekhed66
Gear: Roland JD990 / JD800 / XV5080 / SH-01a,
Behringer DM12, Korg Triton Rack / M1 / Radias,
Akai s5000, Yamaha An1x, Kawai K5000s,
Studiologic Sledge 2
Band: The Creepy Uncles
Re: Yamaha SY77 error on boot
Post by Tekhed66 » Wed Jun 03, 2020 12:46 pm
Try posting here... the VSE help forum can sometimes be a bit quiet... :-/
https://yamahamusicians.com/forum/viewforum.php?f=54
