Korg MS-50 voltmeter lamp
liveinabin
Gear:Korg MS-20, MS-50, SQ-1, ZX-81
Post by liveinabin » Sat May 15, 2021 3:40 pm
I'm busy renovating a much unloved Korg MS-50. Part of it's charm is that big voltmeter in the top right.
However, the light needs replacing in it. I've no idea what to replace it with. The schematics don't seem to give any clue and there's nothing written inside.
Here's a pic (the removed lamp is to the right of the vu window).
Anyone have any idea what I should get or how I could measure what the vu meter needs? Thanks.
Gear:Logic Pro X
Re: Korg MS-50 voltmeter lamp
Post by meatballfulton » Sat May 15, 2021 7:18 pm
Put a voltmeter across the terminals of the existing lamp, then get a bulb of about the same size that's spec'ed for at least that much voltage.
liveinabin
Post by liveinabin » Sat May 15, 2021 10:44 pm
Simple as that? Brilliant. Thanks :)
Measured 14.92. That’ll be 15 volts then I guess.
