Novation K-station encoder part number/type request
belzrebuth
Post by belzrebuth » Sat Jul 17, 2021 3:13 pm
Hi!
Does anyone know what type of encoders the Novation K-station uses?
I could purchase some samples and test which one does the trick but I'd really avoid all that if I had a part number for these.
Yekuku
Re: Novation K-station encoder part number/type request
Post by Yekuku » Sun Jul 18, 2021 8:02 pm
Sorry I dont have the specific part number, but did you contact Novation support ?
The best ever technical support I have ever experienced in my life was from novation and dave smith.
I highly recommend contacting them !
Anyways , whats the problem with the encoder? If it is jumping values, a few drops of deoxit can solve the issue.
It is all about sharing...
belzrebuth
Post by belzrebuth » Sun Jul 18, 2021 8:28 pm
I opened it up and turns out that it doesn't have any encoders apart from the "program" selector encoder.
All the other pots are just regular one-turn 10kB D-shaft potentiometers!
Unfortunately deoxit isn't suitable for any pot (encoders should be fine) in my opinion since it kind of degrades the carbon tracks.
I've used it on many pot until I came to that conclusion.
The best thing for a bad pot would be to replace if of course but I've had very good results by open them up and clean inside with a cotton bud and some IPA, since it's only four to five pots that do weird things I will be doing that.If it was more than that it would make more sense to just replace them because cleaning them takes a bit of time.
They are not mechanically damaged in any way, just dirty so this might do the trick.
Thanks for your tips on Novation support!
Yekuku
Post by Yekuku » Mon Jul 19, 2021 7:15 am
I agree with you , taking the potentiometer apart and cleaning it , is the best way.
Good luck with the repair !
