Oberheim matrix 6 voice LEDs do not light up
Nico63
Post by Nico63 » Mon Aug 02, 2021 6:01 am
Ciao ragazzi, sto cercando una soluzione al mio problema : ho comprato da poco il mio Matrix 6,a quanto pare funziona tutto a parte qualche tasto che sembri suonare su certe patch in modo diverso ma potrei sbagliarmi, il fatto è che non si accende nessun LED delle voci sul display, c'è un modo per disattivarli/attivarli o c'è un anomalia nel synth? Ho già smontato pulito e rimontato tutte le voci ma niente. Esiste un test per controllare le voci? Aiuto!!
English translation (by moderator using Google Translate):
Hi guys, I'm looking for a solution to my problem: I recently bought my Matrix 6, apparently everything works apart from a few keys that seem to play differently on certain patches but I could be wrong, the fact is that none of them light up. Voice LEDs on the display, is there a way to turn them off / on or is there an anomaly in the synth? I have already disassembled clean and reassembled all the items but nothing. Is there a test to check the voices? Help!!
crafter57
Re: Oberheim matrix 6 voice LEDs do not light up
Post by crafter57 » Tue Aug 31, 2021 2:41 am
Ciao Nico, stai bene?
No you cannot turn on/off those voice led's, they are triggered by the CEM filter chips, try swapping the voice chips around if you are getting less than 6 voices to test for the bad CEM. but if its only a few keys, then the obvious would be to check the contacts below the keys, sometimes you could have a broken trace, or open circuit affecting that group of keys or perhaps you have a bad decoder chip not decoding that area on the keybed.
