Hi all. I have recently imported a PG-10 to run my Roland D110 synth. I have read that it needs a PSA series adapter and I see it's a 9v. Does any one know if the modern 9v PSA series (the ones that run my guitar pedals) will be suitable to use with the PG-10?
I only ask because I expected the Roland A800 to run off one of those and when I checked the instructions it turned out it needed my amp PSU instead. However, the instructions for the PG-10 are pretty awful, not D110 awful but bad nonetheless.
Many thanks.
EDIT:-Sorted now. I tried the adapter I had to hand and it powered the unit on. I have a delivery of midi cables coming and will be using it very soon.
Roland PG-10 PSU
- jakethebusker
- Real name: Jake
- Gear: Roland D110 and PG-10
Roland a800 Pro midi controller
Presonus Atom
Presonus Atom SQ
Roland Vdrums td1-dmk
Roland Drum Brain TD-4
