So I have a broken Micron I just acquired. I believe it is suffering from a common ailment, a fried JFET or two. A quick search of these boards and others list the culprit as J111 / JTE468.
I haven't studied electronics in decades so forgive my total ignorance as I am sure this is a stupid question to you gear heads. Is J111 a generic term and JTE468 a brand name version of a J111? Will any J111 work? I found some Fairchild J111 that don't have have a minimum order quantity. So far all the JTE468 I have found have a 10 piece min. which while not outrageous, makes it a little pricey.
I may have to replace the op-amp, TL084 as well.
tl;dr where can I source theses parts on the cheap?
Btw, I live in California
Alesis Micron JFET sourcing
- Real name:Unpronounceable
- Gear:Ensoniq SD-1/32,SQR,VFX,ESQm
TG-33, K3m, Blofeld, Micron, Mopho, BS II, JV-1080 - Band:Eridani V
Re: Alesis Micron JFET sourcing
well, a few years ago i'd have said to go to Fry's... *sighs*
head to Mouser or Digikey to get a j111
So just to be clear, you're saying that any j111 should be fine.
Also, I miss Frys too.
any one in the same package and type should fit.
Thanks for the help
