Behringer BCR2000 to control Sequential Multitrak
First attempts to control my Multitrak with a BCR2000: at the moment I'm using the setup for the SixTrak (most parameters do work) but I've noticed the changes are permanent without storing them manually from the synth. It seems the CC changes from the BCR2000 are stored directly/automatically in the Multitrak...is it supposed to work this way? Or there is something I'm missing? If so, I'd better to copy the preset to a spare memory slot in the synth before changing parameters with the BCR.
