SOLVED: Roland JV-80 Pitch/Mod/C1 not working localy
Posted: Sat Mar 16, 2024 12:48 am
by readymedia
Hi here!
I reactivated my Roland JV-80 after a long break and the PitchBend/ModWeel and C1 are not working localy.
External MIDI gear can control Pitch Bend and Modulation inside JV-80.
In test Mode pitch Bend and Mod Weel and C1 Fader reacts properly according to Service Manual.
I can also see C1 values moving in PATCH : PLAY->CONTROL mode -> "C1 ASSIGN".
[Update]I can control external MIDI gear with JV-80s PichBend/ModWeel and C1. So its for sure something with routing inside JV80.
What could it be?
Maybe a hint can be that the PRESENCE Fader also dont work = But at the other side it is just an analog EQ - so here maybe just the fader is broken.
Update #2: May the magic happens behind the TRANSPOSE button. Have to check it when Im at home.
Update #3: Well, TRANSPOSE button does not help so far ...
Best!, Ready
Re: Roland JV-80 Pitch/Mod/C1 not working localy
Posted: Wed Mar 20, 2024 1:20 am
by readymedia
Me again! ;)
It seems that also TRANSPOSE switch is not working (it light up, but there is no effect). Well, I can change the Transpose Value in the TUNE & FUNCTION menu, but pressing TRANSPOSE button takes no effect then...
So it is still a lack of internal connection from the controllers: Pitch Bend Weel , Mod Weel, C1 Slider, TRANSPOSE knob...
I can easily controll the pitch via LFO 1 oder LFO 2...
Strange...
Posted: Fri Mar 29, 2024 2:52 pm
by readymedia
UPDATE:
Problem solved!
The thing is that my keybed was not attached. I fight the red glue problem in parallel. With keybed attached the JV80 reacts normaly to PitchBend and Modulation. :)))
Best!, Ready
