SH101 - syncing to an external bpm?
arrow
Post by arrow » Wed Jul 26, 2006 3:11 pm
Hi
Just got a Roland sh 101 - dont really understand about the Cv gate/midi stuff but basically all I want to do it be able to sync up the arppegiator to an external midi clock ie ) from the bpm set in ableteon live comming through my external audio interface via midi??
any ideas or knowledge on the topic would be great ???- cheers
godzilla
Post by godzilla » Wed Jul 26, 2006 3:20 pm
you could use something like a tr606 along with a midi - din sync converter
sync the drum machine to the computer, then use its trigger outs to step the arp
i don't actually use midi myself, but i do have a tr606 and an sh101 and i play around with the two together, and as the tr606 does have a sync input this could be an option for you, also the tr606 is a really cool cheap drum machine with a cool analog sound
otherwise i'm sure you could use something else but, as i usually just record my own performances and don't do much sequencing, i don't really know what
arrow
Post by arrow » Thu Jul 27, 2006 3:02 pm
Thanks hadnt thought of that :-)
mitsubishi
CV-MIDI for your SH101
Post by mitsubishi » Thu Sep 28, 2006 10:31 am
Hey,
well I have an SH101 aswell and a doepfer midi to CV (doepfer MCV4)converter. It works absolutly perfect. Check out www.doepfer.com for more info
cheers
Altitude
Post by Altitude » Thu Sep 28, 2006 12:43 pm
A kenton Pro-Solo will work perfectly but I would try just plugging an audio cable into the arp sync on the 101 and send it fast attack quarter notes (like a rimshot)
nathanscribe
Post by nathanscribe » Thu Sep 28, 2006 10:22 pm
Altitude wrote:A kenton Pro-Solo will work perfectly but I would try just plugging an audio cable into the arp sync on the 101 and send it fast attack quarter notes (like a rimshot)
Levels need to be high enough to trigger the arpeg. Check the trigger voltage required. Audio signals may also cause problems with re-triggering due to fluctuations which are a natural part of audio - they are AC signals, and the arpeg normally needs a very short pulse of a few milliseconds, in DC. Probably 2 or 3V up to 12-14V.
Educated guesswork not based on knowledge of the SH, by the way, but I do have some similar gear.
Tonebone
Post by Tonebone » Wed Oct 11, 2006 12:07 am
The roland TR-626 responds to MIDI and has that Trigger out you need. And it can do this shuffle-timing thing like the 909. and it´s relatively cheap (70-90$).
