Hello,
can anyone help out with programing basic stuff on a DX9:
Basic ratios between 2 operators linked in a line ( = carrier + modulator).
For example: CAR set to 1.00 (coarse tune) and MOD to 3.50 (coarse..) gives a bell sound (with the right env. setting of course).
0.50 and 1.75 will yield the same sound (octave lower)
2.00 and 7.00 will be an octave higher..
Various Lead sounds? Strings? Other interesting ideas..
Thanks,
drummer
basic sounds on yamaha DX9
HI drummer.
It depends a lot of Operator Output level too. Try to tweak this for different sounds.
FM programming is a little hard to work with. I would start first with different algorythms and how the connections between ops-mods can determine the final sound.
Roland Promars, E-mu EMAX and some other machines...
What I have to say I posted already here:
http://www.vintagesynth.org/phpBB2/view ... 149#257149
I almost bought a DX9 from my school (this is a long time ago)—they weren't using it any more. But for some reason I didn't in the end. I like how they look similar to the DX7.
- underface
If you haven't done this already, a read through the SoundOnSound Synth Secrets series might prove helpful
Part 12 http://www.soundonsound.com/sos/apr00/a ... ecrets.htm
Part 13 http://www.soundonsound.com/sos/may00/a ... /synth.htm
When you're done with those, go back and read the whole series. It's a little basic in the beginning, but I guarantee you'll learn something.
http://www.soundonsound.com/search?url= ... ummary=Yes
All that said, I agree with Media. Spending a day or two fiddling with it is probably the best way to understand how any given parameter will effect the sound.
- Bitexion
- Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
The output level of the modulator is hugely important, as it acts as a kind of "filter" for harmonics. Low levels throttles harmonics (more muffled), full level is all harmonics (sharp, nasty sound). The output level for carrier only sets the general volume of the set.
You only EVER hear the Carriers in a sound (the operators at the bottom). Operators above the carrier affect the timbre in various ways.
- crystalmsc
- Band: Crystaline
Hope this helps a bit:
http://www.keyboardmag.com/story.asp?storycode=4497
Other useful FM links:
http://www.keyboardmag.com/story.asp?storycode=4496
http://www.fm-alive.com/Downloads/prgrmdx7.pdf
http://www.fm-alive.com/pages/WhatisFM.aspx
Kaossilatron - Voicillator
poor_drummer
